• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Product Support
    Re: AutoCAD MEP 2013 Cui Menus - I'm so confused
    08-22-2012 12:56 PM in reply to: Joshua.Benoist
    I consulted with my team.  We added a sub-menu in the Osnap menu with a new tool and it's working.  You mentioned setting up 2013 as an Enterprise CUI instead of a Main CUI.  You know the Enterprise CUI's are locked, right?  Have you tried it with set as a Main CUI in 2013?
    Joshua
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Product Support
    08-22-2012 01:24 PM in reply to: Joshua.Benoist
    Do you have the MEP.CUI as the enterprise, or any CUI as an enterprise?  You should set the enterprise cui back to be the Main cui.  Then add the custom sub-menu to it.  Then set it back to enterprise.  See if that helps.
    Joshua
    Joshua Benoist, PE
    Product Support
    Autodesk, Inc.
    Product Support
    08-27-2012 02:05 PM in reply to: Joshua.Benoist
    Wanted to follow up and see if the above helped?
    Joshua
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Joshua Benoist, PE
    Product Support
    Autodesk, Inc.
    Distinguished Contributor ken
    08-27-2012 02:10 PM in reply to: Joshua.Benoist
    Sorry I have not tried  your last suggestion, things got crazy here.  I will try to do it tomorrow and I will post back.
    Thanks for still sticking with me on this.
    Sincerely,
    Ken
    08-28-2012 07:15 AM in reply to: ken
    Thanks for all the information, it seems to work now.  I have the MEP.cuix as the Enterprise file on the main server and a Custom.cuix as my main.
    Now the next question is why wont it keep my screen layout as I left it?  I arranged my Toolbars in some order and turn on the menubar but when I exit and return its all back as originally laid out.
    Thanks again for the help I do really appreciate it.
    Sincerely,
    Ken
    Product Support
    08-28-2012 07:24 AM in reply to: Joshua.Benoist
    You probably need to make the toolbar changes before setting an enterprise cui.  Once an enterprise cui is specified, it locks many items down.
    Joshua
    Joshua Benoist, PE
    Product Support
    Autodesk, Inc.
    08-29-2012 08:14 AM in reply to: Joshua.Benoist
    Thanks for all the help, all my menus work now and the workspace is staying the same.  The workspace had to be created / saved and set equal to me in order for it to hold.
    Thanks again for all the help,
    Ken
    08-29-2012 10:26 AM in reply to: ken
    why don't you load the menus you want, enter RIBBONCLOSE and set MENUBAR to (1). This will give you the format you are looking for.
    AutoCAD MEP 2013
    Window 7 pro 64 bit
    E5440 (8 CPU) ~2.8ghZ
    16GB RAM
    NVIDIA QUADRO FX 3500 2270MB
