• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    puck8
    AutoCAD MEP 2012 Switching WorkSpaces causes error message then crash
    137 Views, 2 Replies
    02-06-2012 06:59 AM
    Recently installed AutoCAD MEP 2012 from a Deployment created on a Win 7 x64 Dell T3500
    ran the Deployment successfully on multiple computers. 1 computer gives this message when switching Work Spaces
    Fatal Error Unhandled e0434352h exception at fd83cacdh. AutoCAD crashes then it is launched again, and it opens fine with the selected workspace.
    Product Support
    Re: AutoCAD MEP 2012 Switching WorkSpaces causes error message then crash
    02-13-2012 07:13 AM in reply to: puck8
    Have you tried a clean reinstall?  Is the UAC controls setr to "Never Notify"?  Is the user an Admin?  Did you launch the program for the first time as an Admin or right-click > "Run As Admin?"  Did you use the Microsoft utility to test .NET to see if it was running properly?  I think it's called the ".NET Verification Utility?"  Google will find it.  What's different about that one computer?
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    02-16-2012 09:01 AM in reply to: Joshua.Benoist
    Wanted to follow up and see if the prior suggestions helped?
    Joshua Benoist, PE
    Product Support
    Autodesk, Inc.
