• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Contributor
    AutoCAD 2011 MEP Express tools
    5614 Views, 4 Replies
    05-24-2010 10:45 AM
    Hi all...
    I recently upgraded to MEP 2011. I cannot get express tools to work. I have them pathed to the express folder, and loaded the acetmain.cuix with MENULOAD. I have typed "EXPRESSTOOLS" and "EXPRESSMENU". Both state they have loaded successfully. However, when I try to use any express tools command i get the message "Unknown Command"
    Any idea's???
    Thanks!
    Please use plain text.
    Distinguished Contributor
    Re: AutoCAD 2011 MEP Express tools
    05-25-2010 09:50 AM in reply to: nh0mad
    I had to Add/Remove Programs to install it from the disk. Then, I simply went into CUI and added Express to my current workspace menu. I did not have to path any folders or specifically load anything with MENULOAD. It works OK for me. Do you have the folder called Express in your AMEP 2011 folder?
    05-25-2010 09:52 PM in reply to: nh0mad
    Hi
    If you have load the express tool menu.
    I think you have to customize your workspace (command: CUI) to confirm the express tools checked for the ribbon in this workspace.
    see the attachment.
    Active Contributor
    05-26-2010 08:27 AM in reply to: nh0mad
    Got it...thanks folks!
    Active Contributor
    11-19-2012 10:28 AM in reply to: nh0mad
    what if they are not checked?...no check boxes present??
