• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    kadmonkee8
    Accepted Solution
    Array Dialog Box Displays No More
    1470 Views, 5 Replies
    03-27-2012 06:01 AM
    In the AutoCAD MEP 2012 not all Dialog boxes display automatically.
    Point style dialog box =ddptype in the command line will display for better coordination
    Array Dialog box
    are 2 examples of 2 high demand dialog boxes that don't display
    is this intentional from Autodesk to remove features that aide in its use?
    Is there a fix for this? Please advise.
    Please use plain text.
    Product Support
    Re: Array Dialog Box Displays No More
    03-28-2012 04:01 PM in reply to: kadmonkee8
    Installing Service Pack 1 for AutoCAD MEP 2012 will give you the array dialog window again via the ARRAYCLASSIC command. Here's the link for the update:
    http://usa.autodesk.com/getdoc/id=DL17813065
    There's also some hotfixes that are good to have:
    http://usa.autodesk.com/getdoc/id=DL18022638
    http://usa.autodesk.com/getdoc/id=DL18247986
    http://usa.autodesk.com/getdoc/id=DL18751298
    Let me know if the updates help with the DDPTYPE dialog window too.
    Bryce Thelin
    Product Support
    Autodesk, Inc.
    kadmonkee8
    03-29-2012 03:48 AM in reply to: bryce.thelin
    thank you that fixed the issue
    Product Support
    03-29-2012 08:25 AM in reply to: kadmonkee8
    Excellent! I'm glad to hear that did it for you.
    Bryce Thelin
    Product Support
    Autodesk, Inc.
    Member
    07-31-2012 12:08 PM in reply to: bryce.thelin
    Does this also work for 2013? To obtain the old style dialog boxes - we are having issue with imputing the angle in the rectangular array.
    Product Support
    07-31-2012 01:05 PM in reply to: nbosscha57
    Yes, ARRAYCLASSIC is in AutoCAD 2013. No update is needed to get it into the program like there was with 2012.
    Bryce Thelin
    Product Support
    Autodesk, Inc.
