AutoCAD MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Area Command in AutoCAD MEP 2013
- Highlight
- Email to a Friend
I noticed in an image that you have the Roombook extension. One aspect of Roombook is about getting Areas of the rooms. I reached out to the developers to see if they were aware of any issues. They are not aware of any issues but are investigating. I'll let you know if we learn anything.
Joshua Benoist, PE
Senior Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
We found something that may help. Your video, on the command line you have only one line of prompt history showing. So when the AREA command goes to report the AREA you cannot see it. The command tries to display the total area at the mouse crosshair. Then when Dynamic Dimensions are enabled, it overrides that pop up at the crosshair and so you end up not observing the Area reported anywhere.
So turn off Dynamic Dimensions down near the Osnap toggle buttons. On the command line palette, is a wrench symbol containing the command line settings. In the settings is "Lines of prompt history." Default value is to have 3 lines. Let's see if those changes help.
__________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Your latest suggestion worked! Everything is fine now. Thank you for all your help! Have a wonderful day!
- Highlight
- Email to a Friend
Try to MOVE the objects closer 0. I tried that on a DWG that I just got and then it worked.
BJ
Bjorn J.
- Highlight
- Email to a Friend
I have the same problem in AutoCad Architecture, in both version 2012 and 2013.
I can't get the area-command to terminate. I do not have dynamic dimensions enabled.
Any solutions yet?
I have overcome the problem by drawing polylines and taken the area out of these, but this is not very satisfactory...
- Highlight
- Email to a Friend
I have same problem an autocad architecture 2013. "Distance" command (Measuregeom) doesn't work either. Both fine in 2012
Re: Area Command in AutoCAD MEP 2013 - OOOps
- Highlight
- Email to a Friend
Just found earlier note re Command prompt - everyting now working.
Area Command in AutoCAD LT 2012 is not working
- Highlight
- Email to a Friend
