• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Product Support
    Re: Area Command in AutoCAD MEP 2013
    05-15-2012 09:09 PM in reply to: mahlke.leslye
    I noticed in an image that you have the Roombook extension.  One aspect of Roombook is about getting Areas of the rooms.  I reached out to the developers to see if they were aware of any issues.  They are not aware of any issues but are investigating.  I'll let you know if we learn anything.
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Please use plain text.
    Product Support
    05-16-2012 12:36 PM in reply to: Joshua.Benoist
    We found something that may help.  Your video, on the command line you have only one line of prompt history showing.  So when the AREA command goes to report the AREA you cannot see it.  The command tries to display the total area at the mouse crosshair.  Then when Dynamic Dimensions are enabled, it overrides that pop up at the crosshair and so you end up not observing the Area reported anywhere.
    So turn off Dynamic Dimensions down near the Osnap toggle buttons.  On the command line palette, is a wrench symbol containing the command line settings.  In the settings is "Lines of prompt history."  Default value is to have 3 lines.  Let's see if those changes help.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Joshua Benoist, PE
    Product Support
    Active Member
    05-17-2012 07:31 AM in reply to: Joshua.Benoist
    Your latest suggestion worked!  Everything is fine now.  Thank you for all your help!  Have a wonderful day!
    bjo
    New Member
    05-30-2012 04:44 AM in reply to: mahlke.leslye
    Try to MOVE the objects closer 0. I tried that on a DWG that I just got and then it worked.
    BJ
    Kind regards
    Bjorn J.
    Member
    11-05-2012 05:34 AM in reply to: Joshua.Benoist
    I have the same problem in AutoCad Architecture, in both version 2012 and 2013.
    I can't get the area-command to terminate. I do not have dynamic dimensions enabled.
    Any solutions yet?
    I have overcome the problem by drawing polylines and taken the area out of these, but this is not very satisfactory...
    11-21-2012 07:16 AM in reply to: Joshua.Benoist
    I have same problem an autocad architecture 2013.  "Distance" command (Measuregeom)  doesn't work either.  Both fine in 2012
    Re: Area Command in AutoCAD MEP 2013 - OOOps
    11-21-2012 07:18 AM in reply to: bryarcht
    Just found earlier note re Command prompt  - everyting now working.
    Member
    Area Command in AutoCAD LT 2012 is not working
    01-23-2013 05:39 AM in reply to: mahlke.leslye
    Spoiler
    Hi Sir
    Spoiler
    I have problame with using area command in Autocad LT 2012. The command doesn't let me close the area boundry. it keep asking for " Specify next point". It does not offer a total area quantity.  Does anyone know of a fix for this problem?
