• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    jtechsmith
    Any low voltage contractors using MEP?
    366 Views, 7 Replies
    02-09-2013 10:20 AM
    Looking for some advice from designers and drafters who work for low voltage comapnies that use MEP for designing there systems in a building. Tips on how you use the program, what customizations have you created, etc. I'm in the need for some good tips on how to use the wire tool and customizing panels effectivly for seting up my system.
    Please use plain text.
    Product Support
    Re: Any low voltage contractors using MEP?
    02-11-2013 08:36 AM in reply to: jtechsmith
    Here in support, I have seen a lot of companies using wire for low-voltage.  MEP will not size low-voltage wires and will not make special low-voltage panel schedules that work different from power panel schedules.  So users tend to use the wires for low voltage plan diagrams. Then use regular AutoCAD tables for scheduling.
    Hope this helps,
    Joshua
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Product Support
    02-12-2013 08:39 AM in reply to: Joshua.Benoist
    Following up.  Did the info help?  Does anyone else here in the forums have info to add?  Jump right in.
    Joshua
    Joshua Benoist, PE
    Product Support
    jtechsmith
    02-12-2013 08:48 AM in reply to: Joshua.Benoist
    I guess it gives me some bit of an idea. Question though, if lots of people and companies are using wire for low voltage why not make this accommodation in the software along with panels. Out of the box it has some low voltage icons such as smoke detectors. If there is a way I can custom create a panel for such information. Is there any known third party plugin programs for this? Low voltage equipment and hardware is still a major part in building infrastructure.
    Product Support
    02-12-2013 08:56 AM in reply to: jtechsmith
    This feature does not yet exist in the program.
    We do believe that a low voltage feature that includes low voltage panel schedules would be very helpful to have in the program, and feel that you raise a very good case for enhancing the product.
    If you would take the time to go here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    This is a feedback page where customers can make suggestions. This page is monitored by product managers who affect real change and this request can go a long way in changing the product for the better.
    Have a great day.
    Joshua
    Joshua Benoist, PE
    Product Support
    jtechsmith
    02-12-2013 08:58 AM in reply to: jtechsmith
    quick update 2014 before its released! :smileyvery-happy:
    Valued Contributor
    04-18-2013 01:13 PM in reply to: jtechsmith
    Late reply but here it is..
    We use MEP extensively for fire alarm but out of the box it's useless, we had to beat it into submission over the course of years.  We have created devices with property sets for device addresses, horn mA, speaker watts, Etc.  We have schedule tables which extract this info to show NAC load per circuit, addrssable device details, etc.
    All of our blocks for creating riser diagrams have a wipeout as part of the block and are designed to work on a pre-defined grid template.  It's pretty quick.  We have a similar aproachfor data nad security.
    I have attached a sample sheet, the address you see on devices is a smart tag, created from property set data, same with the NAC circut on  horns, device totals, Etc, all automatically created.
    Good luck.
    jtechsmith
    04-19-2013 05:14 AM in reply to: Mark_Richards
    Incredible. Thanks for responding. I will send you a message later for I have several questions regarding how the heck to program blocks as panels and proform the functions. We have some great blocks that list attributes and model numbers etc. Our big problem is how to add battery and panel load calculators into a panel block.
