AutoCAD MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Add Ducts Menu 2013
- Highlight
- Email to a Friend
- Report Inappropriate Content
I recently upgraded from AutoCAD MEP 2010 to AutoCAD MEP 2013. When I go to Add a Duct in 2013 no menu pops up like it did in 2010. (The Menu title says "Add Ducts - Default Connection Type" ) There you could select your system type of elbows size etc.
Now all that happens is I'll start drawing a duct whatever size I made last. To change all those things I have to go to the Properties menu on the side which seems like more of a hassle.
Does anyone know how to get that menu back? I figure it must just be a setting but I can't find it.
Thanks.
Re: Add Ducts Menu 2013
- Highlight
- Email to a Friend
Everything that was on that menu has now been moved to the property palette. This was done in either the 2011 release or the 2012 I cannot remember which. There is no way to bring that menu back. The good news is that all of the options that were available on that menu are also available on the property palette. There are numerous posts on this board regarding Autodesk's move to put everything on the property palette.
Since you did skip a couple of releases, it would probably be a good idea to go back and read the release notes for 2011 and 2012. This change and many others are spelled out in the release notes for the product.
