AutoCAD MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
AUTOCAD MEP 2013
- Highlight
- Email to a Friend
- Report Inappropriate Content
I AM DRWG. WITH AUTOCAD MEP 2013. I AM NEW TO THIS PROGRAM, I AM DRWG WELDED PIPE AND WANT TO CUT IT UP FOR FAB PIECES, DOES ANYONE KNOW IF THIS PROGRAM ALLOWS FOR THE 1/8 WELD GAPS?
THANK YOU
Re: AUTOCAD MEP 2013
- Highlight
- Email to a Friend
Autocad MEP is not really setup to be a fabrication program. That is not saying that it cannot be with a little setup. First off you will need to check the dimensions of all of the fittings. Some of them are incorrect or do not match a manufacturers specifications. There are no manufacture specific fittings in autocad mep so you will probably want to create your own to validate the dimensions of your fittings. This way you can also add any additional data to the fitting that a schedule can read. Each fitting has what is called a connection enagement length or CEL. This is the value that a pipe will insert into a fitting. You can add a negative value to this so that the pipe will attach outside the fitting instead of inside of it. Since each fitting and pipe will have this connection enagement length you will need to set it to 1/16" so that two of them together will equal 1/8".
