• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Member
    45 degree fittings
    96 Views, 2 Replies
    12-14-2003 12:00 AM
    I fequently need to install an eight been fitting. From time to time, it will not let me do it. I keeps defaulting to a 90 elbow. I find that if I zoom back and install a long pipe run with a 45 it will work. From then on, it will let a 45 be installed. Would like to know why this is happening.
    Please use plain text.
    *[Autodesk], Lars-Ake Johansson
    Re: 45 degree fittings
    12-14-2003 12:00 AM in reply to: RGD1
    Are you refering to the 'Schedule 40
    Glued Eighth Bend US Imperial' in the plumbing piping catalog....?
    Yes, there seems to be a 'problem' with that
    one.....it's configured as a 90 degree bend, not a 45 degree...
    For some reason the Model parameters are corret in
    the part but the Size parameters is incorrect.
    It's an 'easy' fix.
    1. From the MEP Common pulldown menu, choose
    'Content builder'
    2. Choose the Pipe catalog
    3. Browse to Schedule 40 - Glued - Elbows -
    Schedule 40 Glued Eighth Bend US Imperial
    4. Press 'Modify Partsize'
    5. In the tree to the left, right click on 'Size
    Parameters' and choose 'Edit values'
    6. Double click on the field "PathA1" in any of the
    rows
    7. Enter '45' and press 'Enter' (the rest of the
    rows should update with the new value)
    8. Click OK
    9. Press 'Save Part Family'
    10. Press the 'X' to close Content
    Builder
    I have looged this as a defect.
    Sorry for any inconvenience
    Lars-Ake Johansson
    Autodesk BSD QA
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I
    happening.
    Valued Contributor
    I've had many problems as well with 45 degree lateral duct fittings. This is the biggest bug in the program I have found so far.
    I have tried to build 45 degree fittings but the default keeps changing back to 90 degrees. I have contacted Autodesk and am still waiting for a reply.
