• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD MEP
    *Bernhardt, Kyle
    36" Pipe Creation
    126 Views, 8 Replies
    08-04-2003 08:00 AM
    In the course of modelling a mechanical room for a large college campus,
    I've run into the problem that I need larger pipe diameters than are
    available standard. I assumed this was a simply as adding a size to a
    parametric part, which is documented in both the concept guide and then help
    documentation.
    I went ahead and in the content builder, selected "Schedule 40 Flanged Pipe
    US Imperial" from Pipe and Fittings US Imperial->Schedule 40->Flanged->Pipes
    and then chose "add part size" This opens the parametric part environment.
    At this point I click on "Size Parameters" and select "Edit Values". This
    brings me to the "Edit Part Sizes" window. I scroll to the bottom and add a
    new row. Since calculations determine all fields except for the diameter
    and nominal diameter, I only fill these out. I select "Schedule_40" for my
    gauge and "Carbon Steel" for my material. Calculations generate the
    remaining fields. I then select
    "OK". I then run validation tests that return no errors. I save the part
    family and then try and use my new pipe. I am able to select the new pipe
    size in the "Add Pipe" dialog, but when I try and place the part I get the
    following message:
    No pipe with selected gauge and connection type exists in the current
    catalog
    You must change either the gauge or connection type, or switch to a catalog
    that contains this combination before you can add pipe.
    I thought that I might have to regenerate the catalog to create the new
    parametric part size, so I did that and it did not help. I'm not sure where
    to go from here....I really need to be able to add new pipe sizes, and I am
    aware that this requires creating new elbows and tees, but I figured I make
    sure that I could make a pipe first.
    On a related note, I later looked into creating an elbow of the same
    diameter. I noticed that a number of the parameters are not calculated, but
    entered. These are figures like raduis of curvature. If this is a standard
    raduis part, then calculations would define these numbers, but there are no
    calculations in these fields. Leaving me to go and determine the radius of
    curvature for a standard elbow at a 36" diameter for all angles from 1 to
    90. That should be fun. Autodesk you have effectively restrained me, and
    realistically everyone else from creating new pipe diamters, because
    calculating these values and then entering them in would prove way to time
    consuming to be cost effective.
    That being said I'd love to be told that I'm completely wrong and the
    process is painfully simple, cause that would be the logical way to develop
    a program, allowing for the customization the the most commonly used parts,
    so that a MEP consultant can ACTUALLY USE IT. Sorry for the vent there but
    this experience has seriously degraded my view of this program, which I
    pitched to my boss and he subsequently bought.
    And one last thing...roughly 4k for the initial purchase and $900/year for a
    forced subscription cannot provide a place on your website for the uploading
    of parts that were created by the users of your program, for the use in the
    program, even after people have specifically asked for such space? I wonder
    where it all goes, cause my guess is that you already have the
    infrastructure, and it simply requires making available maybe 15-20 gigs
    initially for part uploading. I guess the management doesn't read their
    customer feedback.
    I feel that a large weight has been lifted off my chest.
    Kyle Bernhardt
    Mechanical Engineer
    Dagher Engineering
    29 Broadway
    New York, NY 10006
    Please use plain text.
    *[Autodesk], jason martin
    Re: 36" Pipe Creation
    08-04-2003 09:17 AM in reply to: *Bernhardt, Kyle
    Hi Kyle -
    You can add pipe sizes, but not in the method that you have tried. Pipes are
    not simply parametric parts. They are segments, and as such require some
    special considerations. Content builder was not created to edit segments,
    but was created to edit parts and fittings. To add to the list of availible
    segment sizes you will need to use catalog editor, rather than content
    builder.
    You will need to make two edits in catalog editor to create a new pipe size.
    Launch catalog editor, and open the Pipe US Imperial.apc file. Navigate to
    Schedule 40 -> Flanged -> Connectors. Now I don't have a pipe table in front
    of me to tell me what these values are going to be, so I'm going to "guess"
    some of the values.
    I need to add a new row at the bottom of the Basic Table, with a ND1 of
    36.0, a D1 of 40.0, D2 of 40.0, CL1 of 2.0, and CLE of 1.6.
    Now I need to expand the pipes item, the expand Schedule 40 Flange Pipe,
    expand Basic Table. Add a new row to the bottom of the table with and ND1 of
    36.0 and a D1 of 36.0. Now we need to save the catalog and do a catalog
    regen. Now pipeadd will recognize the new pipesize.
    It doesn't matter what pipe size you try to add, if there isn't a connector
    in a specific size allowed for that gauge and material, it won't be a valid
    pipe size.
    The fact that the parameters for the fittings are not calculated, but are
    based on tables is because if you take a look at these parts in the real
    world, these values are not calculated, but based on tables. It would have
    been much easier for us to base the pipe fitting sizes on equations as well,
    but they aren't manufactured that way. You are welcome to use equations for
    these fields, but we felt that it was better to do more work and get you a
    pipe catalog that meets manufacturer standards than to provide you with
    something that was completely wrong just because it was easy.
    The pipe catalogs are hard to customize. Even harder than the HVAC catalog.
    That is because pipes and pipe fittings are manufactured differently that
    duct and duct fittings.
    Actually if you make the pipes, the fittings can be "approximated" based on
    the existing sizes in the catalogs, so if you want approximations, you don't
    have to even create most of the other fittings.
    We are working on a place for user to put parts, but we don't want everyone
    to have to be an expert in catalog editor and content builder, and to know
    that then need to put parts in a specific place in the catalogs and run
    catalog test and catalog regen to get to the parts, so we are looking for a
    solution that is better than a newsgroup to post files. Until the site is up
    that will allow this you are welcome to post parts to the cf newsgroup as
    some people have already done.
    hth
    jason
    "Kyle Bernhardt" wrote in message
    news:A31EBDC0A09930860B145EDEDEB879F5@in.WebX.maYIadrTaRb...
    help
    > documentation.
    Pipe
    40->Flanged->Pipes
    environment.
    a
    my
    > following message:
    > catalog
    catalog
    where
    am
    make
    but
    standard
    no
    of
    develop
    parts,
    but
    a
    uploading
    the
    wonder
    > customer feedback.
    > Kyle Bernhardt
    > Mechanical Engineer
    > Dagher Engineering
    > 29 Broadway
    > New York, NY 10006
    *Bernhardt, Kyle
    Re:
    08-04-2003 11:12 PM in reply to: *Bernhardt, Kyle
    Jason,
    Ahhh....that certainly makes sense, although I don't remember reading that
    in help documentation. I'd say you might want to add that to the help file
    to be included in the first SP. Question on your instructions though...I
    have figured out that the "CL1" parameter is the thickness of the flange,
    but I haven't been able to determine what the "CLE" variable means. I'd
    like to be able to do this again on another pipe size, but I need to have a
    understanding of what I'm defining so I can do this again.
    As for the upload space, I was thinking that an intermediate spot would be
    adding another newsgroup in the ABS listsings, like this one and abs.wishes,
    rather than the AutoCAD one. I know this isn't the best for people less
    proficient in ABS, but I think that this would be used a lot more due to
    it's location, and foster a more "open source" environment for the program,
    which I think is only good for the program.
    Kyle Bernhardt
    Mechanical Engineer
    Dagher Engineering
    29 Broadway
    New York, NY 10006
    *Bernhardt, Kyle
    Re:
    08-05-2003 12:52 AM in reply to: *Bernhardt, Kyle
    Jason,
    My newly created pipe does not have a normal looking flange. The flange
    does not look like a disk, but rather a slice of a pyramid. This occurs
    only on the 36" pipe, I created 28" and 32" pipe successfully. My connector
    is defined exactly how you said, and the Pipe Basic Table is defined as 36.0
    for both "ND1" and "D1". This follows the convention of other pipe sizes.
    I also am experiencing the same issues with a 42" diameter pipe as I was in
    my first post. I have defined the connectors and the pipe type in the
    catalog editor and regenerated the catalog. This size was created at the
    same time as the other working sizes, so I puzzled. My connector settings
    are ND1=42.0, D1=D2=50.0, CL1=2.5, CLE=2.0, and the pipe is defined in the
    basic table with ND1=D1=42.0. Let me know where I've gone wrong,
    Kyle Bernhardt
    Mechanical Engineer
    Dagher Engineering
    29 Broadway
    New York, NY 10006
    Re:
    08-05-2003 12:04 PM in reply to: *Bernhardt, Kyle
    Hi Kyle -
    Not sure why your pipe isn't working correctly. I've attached some images of
    the 36" I created with the settings that I gave you.
    The CLE param is Cut Length Extension... This has something to do with the
    distance that the segment is cut back to allow for the "flange" to be placed
    at the end of the pipe. I'm not in the office for the rest of this week, but
    when I get back in I'll try to get with out expert on this and figure out
    exactly what the CLE is used for.
    Would you mind posting your connector and pipe xml files (or you can just
    email them to me directly). I'll see if I can figure out why your flanges
    are busted.
    jason
    news:C266DFC2D1507CDA3BB3CDB33B3621DB@in.WebX.maYIadrTaRb...
    > Jason,
    connector
    36.0
    in
    > Kyle Bernhardt
    > Mechanical Engineer
    > Dagher Engineering
    > 29 Broadway
    > New York, NY 10006
    Re:
    08-05-2003 12:05 PM in reply to: *Bernhardt, Kyle
    Ooopsss, no images... Try again
    *[Autodesk], Peter Terwilliger
    Re:
    08-05-2003 11:00 PM in reply to: *Bernhardt, Kyle
    Jason -
    The Cut Length Extension is exactly that. It is the length of pipe that
    would go into a slip-on flange, for example. It was done to more accurate
    model the actual lengths of pipe for scheduling purposes. It wouldn't be
    that far of a stretch to add additional lengths for pullback and
    gasketing...
    I hope this helps!
    "jason martin [Autodesk]" wrote in message
    news:3979518476F04751656AA68A7A23F27D@in.WebX.maYIadrTaRb...
    > Hi Kyle -
    of
    placed
    but
    > are busted.
    > jason
    > > Jason,
    > connector
    > 36.0
    sizes.
    > in
    the
    settings
    the
    > > Kyle Bernhardt
    > > Mechanical Engineer
    > > Dagher Engineering
    > > 29 Broadway
    > > New York, NY 10006
    *Bernhardt, Kyle
    Re:
    08-06-2003 04:50 AM in reply to: *Bernhardt, Kyle
    Jason,
    I fixed the problem myself. It was my fault cause I originally defined the
    pipe wrong, and did not purge the objects from the drawing and then
    regenerate. Doing this solved the problem and I now have 42" pipe and
    correct looking 36" pipe.
    Kyle Bernhardt
    Mechanical Engineer
    Dagher Engineering
    29 Broadway
    Re:
    08-06-2003 08:07 AM in reply to: *Bernhardt, Kyle
    See, that's why you DON'T want an electrical guy answering questions on
    flanges. Thanks for the follow up Pete!!
    Kyle -
    Glad you got the flanges working correctly.
    "Peter Terwilliger [Autodesk]" wrote in
    message news:53ADE3E2EF9D48F66100134BED5C2888@in.WebX.maYIadrTaRb...
    > Jason -
    > gasketing...
    > I hope this helps!
    > > Hi Kyle -
    images
    > of
    the
    > placed
    > but
    out
    just
    flanges
    > > are busted.
    > > jason
    > > > Jason,
    flange
    occurs
    > > connector
    as
    > > 36.0
    > sizes.
    was
    > > in
    > the
    > settings
    > the
    > > > Kyle Bernhardt
    > > > Mechanical Engineer
    > > > Dagher Engineering
    > > > 29 Broadway
    > > > New York, NY 10006
