• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Distinguished Contributor
    3-Way Diffusers
    100 Views, 2 Replies
    07-23-2003 11:30 PM
    How do I so a 3-way and 2-Way Diffusers in plan view. Normally I would hatch the 1 or 2 sides of the diffuser that is not being used, But I can't hatch MV Parts.
    The only option I can think of without creating a new MVpart is to draw a pline ofer the MVpart then hatch the object. Any other options?
    Toma1379
    A+E Group
    Please use plain text.
    *[Autodesk], Peter Terwilliger
    Re: 3-Way Diffusers
    07-24-2003 12:23 AM in reply to: tarmbruster
    Hi Toma -
    You will need to hatch the view block used in the
    plan view.  An example of what you want to do is contained in the 18 x 18
    Square Louver Face Ceiling Diffuser.  It uses hatched blocks in for the
    schematic blocks.
    Come to think of it, the ABS 3 IsoSchematic display
    config (which was the only display configuration that used the symbol view) may
    have been removed from ABS 2004 templates for some reason.  It enabled you
    to see everything in one line with the MvParts as symbols - essentially a
    to-scale isometric.  You can recreate it easily enough by changing the
    Display Set "ABS Floor Plan 1 Line" setting for MvParts from "2 Line" to
    "Schematic", then view everything in the Display configuration ABS Floor
    1-Line.
    I hope this helps!
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    How
    Toma1379
    A+E Group
    *[Autodesk], jason martin
    Re:
    07-24-2003 12:25 AM in reply to: tarmbruster
    You could also use flow arrows, with a custom block so that you could show
    the same part as either a 2 way or 3 way flow. To do this right click the
    part and go to MvPartProperties -> Flow tab.
    jason
    "Peter Terwilliger [Autodesk]" wrote in
    message news:34A742F4A0504F6F5E7241B0CE8E651D@in.WebX.maYIadrTaRb...
    > Hi Toma -
    > You will need to hatch the view block used in the plan view. An example
    of what you want to do is contained in the 18 x 18 Square Louver Face
    Ceiling Diffuser. It uses hatched blocks in for the schematic blocks.
    > Come to think of it, the ABS 3 IsoSchematic display config (which was the
    only display configuration that used the symbol view) may have been removed
    from ABS 2004 templates for some reason. It enabled you to see everything
    in one line with the MvParts as symbols - essentially a to-scale isometric.
    You can recreate it easily enough by changing the Display Set "ABS Floor
    Plan 1 Line" setting for MvParts from "2 Line" to "Schematic", then view
    everything in the Display configuration ABS Floor 1-Line.
    > I hope this helps!
    > "Toma1379" wrote in message
    news:f17a7f5.-1@WebX.maYIadrTaRb...
    hatch MV Parts.
    > Toma1379
    > A+E Group
