• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP Wishes
    Member
    size of contour is too big
    505 Views, 0 Replies
    11-14-2010 10:35 AM
    symbol of conection electrical an plumbing are too big and hide the objet
    Hello.
    I'm drawing in autocad MEP
    mi drawing setup is:
    units meters.
    i did inserted (for plumbing and electrical) any equipment with terminal for conections and for each one of the conection there are one symbol (triangle with !)  my problem is the size of this symbol, is too big!!  and i can't resize it  , if i turn off his layer, all this objet is invisible.
    The image attached: four viewports of my problem: different zoom on plan and 3Dview,
    The diameter of this simbol is   0.10 meter
    In drawing BAÑO.DWG insert WC, wall mounted lavatory and drain plumbing.
    Thanks. I can't work with many objets, all them has its own symbol(s) for each conection!!!
    Please use plain text.
