AutoCAD MEP Wishes (Read Only)
fix electrical schematic and layout palette
0 REPLIES 0
Message 1 of 1
Jim Hoselton
209 Views, 0 Replies
In ABS 2006, when I go to "Electrical schematic and Layout" Palette and select an "Add ..." tool like "Add power device" the system definitions listed are Chilled Water, Condenser Water, Etc.. which are mechanical schematic system definitions that should not be associated to ANY electrical system. I should be seeing 120V power, 120V ligthing, etc..
I checked with reseller tech support and they have same listing I have. What it looks like is someone used the ADD SCHEMATIC SYMBOL dialog box from Mech/piping palette for the Electrical without updating the dialog box to use electrical system definitions.
Please fix this.... Chilled Water and electric power don't mix well...shocking... I know...
0 REPLIES 0
