• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD MEP Wishes
    Active Contributor
    Re: Parametric Parts
    10-14-2011 03:12 AM in reply to: martin.schmid
    Good stuff, Im actually convinced its more to do with the windows XP OS, we will soon be moving to win.7 so perhaps thiswill help.
    Its so random I don't think I can recreate it, but the next time it crashes I will send you the drawing & the error data.
    Thanks for looking into it.
    Brian.
    Please use plain text.
    Employee
    10-14-2011 03:17 AM in reply to: brian.breslin
    Hi Brain- I'll happily let you blame XP :smileyhappy:.  However, if you do continue to have problems with this issue, please don't be hesitant to contact me via email directly: martin dot schmid at autodesk dot com    ....
    Martin Schmid, P.E.
    Product Manager - Analysis and Countrification
    Architecture, Engineering, and Construction
    Autodesk, Inc.
    Active Contributor
    10-14-2011 03:30 AM in reply to: martin.schmid
    lol. I blame Microsoft for a lot of stuff.:smileyhappy:
    I will forward your good self teh next crash info. no problem.
    Active Contributor
    10-19-2011 07:16 AM in reply to: martin.schmid
    Martin another crash.
    This time I was only tabbing between 6 open files. Never got round to doing any work.
    Before this I did have MEP & REVIT MEP open doing a wee 3d manhole detail, but these were closed. PC did seem to be running slowly after this though?
    Hope this is of some use.
    I think my windows had just had enough tbh.
    Cheers.
    BB
    Employee
    10-21-2011 07:10 AM in reply to: brian.breslin
    Hi Brian- I think this will be helpful.  I've sent some data to the dev team to dig into.
    Martin Schmid, P.E.
    Autodesk, Inc.
    Active Contributor
    10-27-2011 07:49 AM in reply to: martin.schmid
    Glad it might help. look forward to some answers.
    Are you off to the AU this year?
    Cheers.
    Brian.
    Employee
    10-28-2011 01:30 AM in reply to: brian.breslin
    AU - I'm a definitive maybe on that front at present.
    Martin Schmid, P.E.
    Autodesk, Inc.
    Active Contributor
    06-14-2012 03:21 AM in reply to: martin.schmid
    Finding the Families in Revit much easier to edit than AutoCAD MV parts martin.
    MV parts could be improved greatly if you could edit them after they where created like families can be edited.
    Just some further thoughts after recent experiences.
    How was AU?
    *Expert Elite*
    Keith.Brown
    07-17-2012 10:55 AM in reply to: brian.breslin
    If you part is parametric you can easily open it using the content builder and make changes.  If your part is block based you can open the individual blocks and make your edits there by opening up the dwg found in the part catalog.
    Content Builder is definately not on par with the family editor.  If autodesk could improve content builder to act like the family editor I think that more people would create their own parts.
    Keith Brown AutoCAD MEP BLOG | RSS Feed
