• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD MEP Wishes
    New Member
    DEVICE COUNT
    96 Views, 12 Replies
    09-18-2003 03:59 AM
    I use to have a block count file that would list all blocks in a dwg. and give the quantity of each block. Building systems3 does not use blocks, its all devices. Is there a way to list all the "devices" within a dwg specifying "system names", "style names" as well as quantity?
    Please use plain text.
    *[Autodesk], Hakan Wikemar
    Re: DEVICE COUNT
    09-22-2003 04:24 PM in reply to: DR.WICK
    Hi Wick!
    I don't really know how you want the result
    presented or how your block count file worked. Do you want an external file that
    shedules all your devices or is it enough to have them presented in the dwg? If
    so h
    ave you tried to use the property set
    definitions and shedule table functions to create a table in the drawing? If you
    do so you can right-click on the table and exprt the info to a txt or a xls
    file.
    commands:
    aecstylemanager - documentation objects -
    property sets and shedule tables, (add a property set that applies to devices
    and that includes the automatic properties: style and system, then create a new
    shedule style that applies to devices, with the columns style and system + check
    the include quantity column)
    apply the propertyset to all your devices through
    the properties pallette - extended data tab
    tableadd - choose your table style - include all
    devices - add your shedule table
    If you want to just extract info of all the devices
    directly to a txt file or something you will probbably need to write a vba macro
    or something.
    Please let me know a bit more of what you need
    and I'll try to help you.
    /Hakan (QA)
    I
    Re:
    09-24-2003 09:58 PM in reply to: DR.WICK
    Hi again!
    I made a small vba file you could try to get an
    idea of what you can do and how.
    Just do a vbaload and vbarun to try it. (vbaman to
    edit)
    Posting it under the same heading in Customer files
    area.
    /Hakan
    Hi Wick!
    that shedules all your devices or is it enough to have them presented in the
    dwg? If so h
    set definitions and shedule table functions to create a table in the drawing?
    If you do so you can right-click on the table and exprt the info to a txt or a
    xls file.
    commands:
    new shedule style that applies to devices, with the columns style and system +
    check the include quantity column)
    table
    devices directly to a txt file or something you will probbably need to write a
    vba macro or something.
    need and I'll try to help you.
    /Hakan (QA)
    I
    quantity?
    Active Contributor
    Re: DEVICE COUNT
    10-03-2003 01:19 AM in reply to: DR.WICK
    Not to sound ignorant, I just started using "Building Systems" and I have no idea how to do what you are sugesting, but it sounds like there is no easy way to count devices in a drawing. I dont need to put this info into a table, but I need it to get a basic count for reference. The only other way that I know of is to print out the drawing and count each individual device. This can take hours and there is the possibility of missing a couple.
    Re:
    10-05-2003 06:58 PM in reply to: DR.WICK
    I'm sorry if I wasn't clear enough in my first
    reply.
    What I was trying to say was that you can do a
    couple of things to count the devices in the drawing.
    a. You can set up schedule tables that count your
    devices and have them presented in your drawing. If you just want them for
    reference you can just delete them after you have used them.
    b. Or you can run a script that I put together that
    creates a txt file which lists all the devices in the dwg.
    I'll try and describe the procedures as detailed as
    possible, if you have any questions don't hesitate to ask.
    commands to write on the command line in
    italic
    a.
    While it may look like big task to set up the
    schedule tables it's quite easy and you can later on reuse these settings in
    other dwg's by just copying the property sets and schedule table styles to every
    new drawing, or save them in your template dwg.
    1. aecstylemanager, look for Property Set
    Definitions in the left pane, right-click and select NEW. Name it to something
    appropriate such as Device.
    2. Select the new Property set in the right pane,
    right-click and select Edit
    3. Select the tab Applies To, Click Clear all,
    scroll down in the all objects list and select Device
    4. Change too Definition Tab, Click on Add
    Automatic.... Select Style and Click OK, Click on Add Automatic...
    again Select System and Click OK
    5. Click OK, (We have now created a property set
    that can be attached to devices)
    6. Still in the Style Manager, look for Schedule
    Table Styles, Right-Click and select New and name it to something appropriate
    such as Device Schedule.
    7. Right-Click on the New Style and select
    Edit...
    8. Select the
    tab Applies To, Click Clear all, scroll down in the all objects list and select
    Device
    9. Select the Columns Tab and Select the Include
    Quantity Column.
    10. Click Add Column...
    select Style (probably selected by default) in the left hand side and
    click OK, then Click Add Column... again and select System and Click
    OK.
    11. Click OK. (We have now created the schedule
    style which includes Quantity, Style and System on devices)
    12. Return to your dwg (select ok to exit the style
    manager.)
    13. Select all devices (for ex use Ctrl+a,
    and right-click and choose quick select, select device in the dropdown
    and hit ok.
    14. When you have all devices selected;
    right-click and select Device Properties.
    15. In the General Tab Click Property Sets...,
    Click Add... (you should now see the name of the Property Set you created) make
    sure your property set is selected and click ok, then ok and ok.
    We have now Attached the property sets to our
    devices (you will have to add property sets to every additional device you
    insert to the drawing but you can always select all devices and add again to
    make sure you have added them to all devices)
    16. tableadd, Select your Schedule table
    style and select the Add New objects automatically and Automatic Update.
    OK.
    17. Select the whole dwg surface, Place The
    schedule.
    If you save this dwg, you can through the
    aecstylemanager copy and paste the table style and Property set
    definitions into other dwg's.
    b.
    1. Get my ElecCount.zip file from the
    autodesk.autocad.customer-files (Under DEVICE COUNT header) unzip it and save
    the ElecCount.dvb file somewhere.
    2. vbaload, browse to the file and load
    it. (if a question comes up about running macros select Enable
    Macros)
    3. vbarun, Run.
    4. Select Save As.. and navigate somewhere
    where you want to save the txt file.
    5. Quit the Script and look at the txt file.
    If you rather would like to have the # of devices
    presented in a dialog box or something let me know and I'll see what I can
    do.
    /Hakan
    Not
    couple.
    Active Contributor
    Re:
    10-09-2003 04:11 AM in reply to: DR.WICK
    Thank you for the vba file!!! It works better than the block count that I used up until R2002. Not that its important, is there a way to tweak the file so that it will group the devices together? Such as all the lighting together, all power, fire alarm, and so on?
    Once again, THANK YOU!!
    You saved me a lot of time with this file!
    Active Contributor
    Re:
    12-06-2005 02:48 PM in reply to: DR.WICK
    Hello Hakan,
    You had helped me with this device count dvb file. I now have ASB2005 and it is telling me that it cant find a project or a library. I don't know if this file is compatible with 2005, if something needs to be re-written or if a new file needs to be created all together in order for it to work in 2005. Any suggestions?
    Thanks!
    Employee
    Re:
    01-15-2006 10:26 AM in reply to: DR.WICK
    Hi Wick-
    Chances are you need to update the references in the VBA project. To do this, enter VBAIDE. From the Tools menu, select References... What references you need to select depends on what Objects were used in the project... but likely that you will at least need:
    AEC Building Systems 4.5 Base Object Library
    and perhaps:
    AEC Building Systems 4.5 Application Library.
    Hope this helps,
    MS
    Martin Schmid, P.E.
    Product Manager - Analysis and Countrification
    Architecture, Engineering, and Construction
    Autodesk, Inc.
    Active Contributor
    Re:
    01-17-2006 09:13 AM in reply to: DR.WICK
    Thank you MS!
    I guess I had some missing files, but this fixed my problem. My next question is, is there a way that I can run this and have all my devices grouped together. For example: list all of my "power devices" together, all "fire alarm devices" together, all "lighting devices" grouped together and so on? I also wanted to know if there is a way to display my "device count" within the AutoCAD text window, as opposed to having it exported to a separate file. I am not very familiar with the VBA, so please bare with me.
    Thanks again!
    Wick
    Employee
    Re:
    01-17-2006 10:00 AM in reply to: DR.WICK
    Wick--
    I don't readily see a way to get the Classification information (lighting, power, fire alarm, etc...) via VBA. The alternate way I see to do this is via a Schedule. You can define the schedule to sort by the Device Type (Classification). Refer to the attached.
    If I learn that it is possible via VBA, I'll post back to this forum.
    Martin Schmid, P.E.
    Autodesk, Inc.
