AutoCAD MEP Wishes (Read Only)
Message 1 of 13
880 Views, 12 Replies
DEVICE COUNT
I use to have a block count file that would list all blocks in a dwg. and give the quantity of each block. Building systems3 does not use blocks, its all devices. Is there a way to list all the "devices" within a dwg specifying "system names", "style names" as well as quantity?
12 REPLIES 12
Message 2 of 13
Hi Wick!
I don't really know how you want the result
presented or how your block count file worked. Do you want an external file that
shedules all your devices or is it enough to have them presented in the dwg? If
so h
ave you tried to use the property set
definitions and shedule table functions to create a table in the drawing? If you
do so you can right-click on the table and exprt the info to a txt or a xls
file.
commands:
aecstylemanager - documentation objects -
property sets and shedule tables, (add a property set that applies to devices
and that includes the automatic properties: style and system, then create a new
shedule style that applies to devices, with the columns style and system + check
the include quantity column)
apply the propertyset to all your devices through
the properties pallette - extended data tab
tableadd - choose your table style - include all
devices - add your shedule table
If you want to just extract info of all the devices
directly to a txt file or something you will probbably need to write a vba macro
or something.
Please let me know a bit more of what you need
and I'll try to help you.
/Hakan (QA)
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Message 3 of 13
Hi again!
I made a small vba file you could try to get an
idea of what you can do and how.
Just do a vbaload and vbarun to try it. (vbaman to
edit)
Posting it under the same heading in Customer files
area.
/Hakan
Hi Wick!
that shedules all your devices or is it enough to have them presented in the
dwg? If so h
set definitions and shedule table functions to create a table in the drawing?
If you do so you can right-click on the table and exprt the info to a txt or a
xls file.
commands:
new shedule style that applies to devices, with the columns style and system +
check the include quantity column)
table
devices directly to a txt file or something you will probbably need to write a
vba macro or something.
need and I'll try to help you.
/Hakan (QA)
I
quantity?
Message 4 of 13
Not to sound ignorant, I just started using "Building Systems" and I have no idea how to do what you are sugesting, but it sounds like there is no easy way to count devices in a drawing. I dont need to put this info into a table, but I need it to get a basic count for reference. The only other way that I know of is to print out the drawing and count each individual device. This can take hours and there is the possibility of missing a couple.
Message 5 of 13
I'm sorry if I wasn't clear enough in my first
reply.
What I was trying to say was that you can do a
couple of things to count the devices in the drawing.
a. You can set up schedule tables that count your
devices and have them presented in your drawing. If you just want them for
reference you can just delete them after you have used them.
b. Or you can run a script that I put together that
creates a txt file which lists all the devices in the dwg.
I'll try and describe the procedures as detailed as
possible, if you have any questions don't hesitate to ask.
commands to write on the command line in
italic
a.
While it may look like big task to set up the
schedule tables it's quite easy and you can later on reuse these settings in
other dwg's by just copying the property sets and schedule table styles to every
new drawing, or save them in your template dwg.
1. aecstylemanager, look for Property Set
Definitions in the left pane, right-click and select NEW. Name it to something
appropriate such as Device.
2. Select the new Property set in the right pane,
right-click and select Edit
3. Select the tab Applies To, Click Clear all,
scroll down in the all objects list and select Device
4. Change too Definition Tab, Click on Add
Automatic.... Select Style and Click OK, Click on Add Automatic...
again Select System and Click OK
5. Click OK, (We have now created a property set
that can be attached to devices)
6. Still in the Style Manager, look for Schedule
Table Styles, Right-Click and select New and name it to something appropriate
such as Device Schedule.
7. Right-Click on the New Style and select
Edit...
8. Select the
tab Applies To, Click Clear all, scroll down in the all objects list and select
Device
9. Select the Columns Tab and Select the Include
Quantity Column.
10. Click Add Column...
select Style (probably selected by default) in the left hand side and
click OK, then Click Add Column... again and select System and Click
OK.
11. Click OK. (We have now created the schedule
style which includes Quantity, Style and System on devices)
12. Return to your dwg (select ok to exit the style
manager.)
13. Select all devices (for ex use Ctrl+a,
and right-click and choose quick select, select device in the dropdown
and hit ok.
14. When you have all devices selected;
right-click and select Device Properties.
15. In the General Tab Click Property Sets...,
Click Add... (you should now see the name of the Property Set you created) make
sure your property set is selected and click ok, then ok and ok.
We have now Attached the property sets to our
devices (you will have to add property sets to every additional device you
insert to the drawing but you can always select all devices and add again to
make sure you have added them to all devices)
16. tableadd, Select your Schedule table
style and select the Add New objects automatically and Automatic Update.
OK.
17. Select the whole dwg surface, Place The
schedule.
If you save this dwg, you can through the
aecstylemanager copy and paste the table style and Property set
definitions into other dwg's.
b.
1. Get my ElecCount.zip file from the
autodesk.autocad.customer-files (Under DEVICE COUNT header) unzip it and save
the ElecCount.dvb file somewhere.
2. vbaload, browse to the file and load
it. (if a question comes up about running macros select Enable
Macros)
3. vbarun, Run.
4. Select Save As.. and navigate somewhere
where you want to save the txt file.
5. Quit the Script and look at the txt file.
If you rather would like to have the # of devices
presented in a dialog box or something let me know and I'll see what I can
do.
/Hakan
Not
couple.
Message 6 of 13
Thank you for the vba file!!! It works better than the block count that I used up until R2002. Not that its important, is there a way to tweak the file so that it will group the devices together? Such as all the lighting together, all power, fire alarm, and so on?
Once again, THANK YOU!!
You saved me a lot of time with this file!
Message 7 of 13
Hello Hakan,
You had helped me with this device count dvb file. I now have ASB2005 and it is telling me that it cant find a project or a library. I don't know if this file is compatible with 2005, if something needs to be re-written or if a new file needs to be created all together in order for it to work in 2005. Any suggestions?
Thanks!
Message 8 of 13
Martin__Schmid
Hi Wick-
Chances are you need to update the references in the VBA project. To do this, enter VBAIDE. From the Tools menu, select References... What references you need to select depends on what Objects were used in the project... but likely that you will at least need:
AEC Building Systems 4.5 Base Object Library
and perhaps:
AEC Building Systems 4.5 Application Library.
Hope this helps,
MS
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
Message 9 of 13
Thank you MS!
I guess I had some missing files, but this fixed my problem. My next question is, is there a way that I can run this and have all my devices grouped together. For example: list all of my "power devices" together, all "fire alarm devices" together, all "lighting devices" grouped together and so on? I also wanted to know if there is a way to display my "device count" within the AutoCAD text window, as opposed to having it exported to a separate file. I am not very familiar with the VBA, so please bare with me.
Thanks again!
Wick
Message 10 of 13
Martin__Schmid
Wick--
I don't readily see a way to get the Classification information (lighting, power, fire alarm, etc...) via VBA. The alternate way I see to do this is via a Schedule. You can define the schedule to sort by the Device Type (Classification). Refer to the attached.
If I learn that it is possible via VBA, I'll post back to this forum.
Martin Schmid
Autodesk, Inc.
Message 11 of 13
Is there a way to count devices throughout a set of drawings? Sorry if this is a dumb question, I don't have ABS (yet) I'm just curious about it's capabilities.
I usually put one level/floor of a building on it's own drawing so I guess I would just need a way to add up the totals from the method you described.
I'm not as lazy as I sound, It would just be nice to have a total count automated and not have to wonder if I missed a device or my addition was correct.
Will the quantities update on the tables after revisions or must you go through the whole schedule table creation process again? I assume you would, just wishfully thinking.
Message 12 of 13
Yes, you can schedule items that are in external drawing files and you can
either manually refresh the tables or have it automatically update.
wrote in message news:5270896@discussion.autodesk.com...
capabilities.
correct.
Message 13 of 13
Outstanding. How about counting conduit and cable lengths?
I do fire alarm system drawings, if it's installed in conduit, the conduit size varies according to the quantity of cables. Also, there is often multiple, multi-conductor cables of various sizes.
I believe ABS will do pipe automatically, correct?
Can I set up devices for cables to where the conduit will automatically be sized according to the fill ratio of the cables within? Or can it at least warn me if the conduit is too small?
Can I tag the conduit and have the type, size and quantity of conduit and cables inserted into the tag automatically?
IE:
1A, 4B, 2C, (1) 2" EMT
I'm not sure what program to look at. I already have AutoCAD. would I be able to do something like this in Architectural Desktop, or in AutoCAD with customization? Right now I just draw a polyline and tag it with a dimension leader and hook/arrow. The hard part is adding it all up and updating the totals after revisions.
Even if I could do that with one multi-conductor cable in one size conduit, It would make my burden tremendously lighter. Message was edited by: Freakzilla
