AutoCAD MEP Wishes
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Andrew
Connection Points
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
45 Views, 7 Replies
11-04-2003 01:29 AM
When specifying connection points is style manager we need a "Pick Point"
option. It is very cumbersome to measure where each point is, write it
down, then key it in. More importantly, not every connection point falls
into autocads 1/256 accuracy. Some connections can't be made exactly where
they need to be.
they need to be.
*Andrew
Re: Connection Points
Options
- Highlight
- Email to a Friend
11-11-2003 12:21 AM in reply to:
*Andrew
Take 2:
A simple on/off toggle in the device style under connectors that would link
connectors together. So when one connector on a device is assigned a
circuit number, all connectors on that device are assigned that number.
"Andrew" wrote in message
news:25D4AEEAA4FDB7954729135CB327183F@in.WebX.maYI adrTaRb...
where
> they need to be.
"Andrew"
where
> they need to be.
*[Autodesk], jason martin
Re:
Options
- Highlight
- Email to a Friend
11-11-2003 02:32 AM in reply to:
*Andrew
Hi Andrew -
I'm a little confused about this. Why do you want multiple connectors it
they all have the same data? Why not just use a single connector on the
device?
jason
news:C007444207851BAECB4C5A580D4DEC00@in.WebX.maYI adrTaRb...
> Take 2:
link
device?
jason
"Andrew"
> Take 2:
link
*Andrew
Re:
Options
- Highlight
- Email to a Friend
11-11-2003 04:18 AM in reply to:
*Andrew
1. For appearance. Some devices look sloppy when circuiting is all
connected to a single connection point. Light fixtures for example. If the
middle of the fixture is the connection point with the "trace geometry"
cleanup set, wiring can look like a spider web coming out of it from all
directions. With connection points set to the four quadrants or the mid
point of each side, the drawing looks much cleaner.
2. For design. Our surface mount fixtures are according to most standards.
They are a rectangle with a circle inside. The circle represents where the
fixtures will be wired together or a j-box. So the circuiting (for us)
should be shown to the circle. The program doesn't allow to have one
connection point in the center of the fixture and have "trace geometry"
clean the wire to the circle. It is only cleaned to the outside of the
rectangle. With connection points set to the four quadrants of the circle,
I can accomplish this.
"jason martin [Autodesk]" wrote in message
news:37F101E8EF852F69C82F565EB9AA195E@in.WebX.maYI adrTaRb...
> Hi Andrew -
> device?
> jason
> > Take 2:
> link
> Hi Andrew -
> device?
> jason
> "Andrew"
> > Take 2:
> link
Re:
Options
- Highlight
- Email to a Friend
11-11-2003 04:48 AM in reply to:
*Andrew
Hi Andrew -
So rather than having additional connectors, what you are looking for is
better control of the wire snaps and wire cleanup with the devices.
Allowing you to assign a connector to a piece of geometry within the device
definition, so that you get a econ snap point anywhere along this geometry
would help to solve your problem? If this piece of geometry would also scale
with the device (if it scales), and you could create the geometry "visually"
rather than specifying "points", it could probably solve a couple other
problems as well.
Please understand, I'm not trying to argue with you about this... Just
trying to determine your needs!
jason
news:3B4EE413AB3A08C74AA8CB6889D74D86@in.WebX.maYI adrTaRb...
the
standards.
the
circle,
> > Hi Andrew -
> > device?
> > jason
> > > Take 2:
> > link
number.
problems as well.
jason
"Andrew"
the
standards.
the
circle,
> > Hi Andrew -
> > device?
> > jason
> > "Andrew"
> > > Take 2:
> > link
number.
*Andrew
Re:
Options
- Highlight
- Email to a Friend
11-11-2003 05:39 AM in reply to:
*Andrew
Exactly. This would solve the problem presented in the ABS2004 group with
multiple branch circuits under the heading "Connectors". Only one connector
is needed to supply the appropriate data for circuiting the device, but any
point on that device could be circuited to.
news:6208E504638EFC068EE8844BB13B2ECA@in.WebX.maYI adrTaRb...
> Hi Andrew -
device
scale
"visually"
> problems as well.
> jason
> the
> standards.
> the
> circle,
> > > Hi Andrew -
it
the
> > > device?
> > > jason
> > > > Take 2:
would
> > > link
a
> number.
> Hi Andrew -
device
scale
"visually"
> problems as well.
> jason
> "Andrew"
> the
> standards.
> the
> circle,
> > > Hi Andrew -
it
the
> > > device?
> > > jason
> > > "Andrew"
> > > > Take 2:
would
> > > link
a
> number.
*Snocker, John
Re:
Options
- Highlight
- Email to a Friend
11-13-2003 10:13 PM in reply to:
*Andrew
We've done the same thing with our recessed fixtues. The designers want the
wires shown to the quadrants of the circle in the middle of the device. We
aren't using the calculation features of BS yet as several of the engineers
feel they are too old to pickup drafting.
For us if you could have the
snap point at the center still but allow masking of only the inner circle,
it'd be acceptable. Thanks!
-John Snocker
news:E1E73A6FD8894E83085B29256F67C755@in.WebX.maYI adrTaRb...
connector
any
> > Hi Andrew -
> device
geometry
> scale
> "visually"
> > problems as well.
> > jason
If
> > the
geometry"
all
mid
> > standards.
where
> > the
us)
geometry"
the
> > circle,
> > > > Hi Andrew -
connectors
> it
> the
> > > > device?
> > > > jason
> > > > > Take 2:
> would
> > > > link
assigned
> a
> > number.
-John Snocker
"Andrew"
connector
any
> > Hi Andrew -
> device
geometry
> scale
> "visually"
> > problems as well.
> > jason
> > "Andrew"
If
> > the
geometry"
all
mid
> > standards.
where
> > the
us)
geometry"
the
> > circle,
> > > > Hi Andrew -
connectors
> it
> the
> > > > device?
> > > > jason
> > > > "Andrew"
> > > > > Take 2:
> would
> > > > link
assigned
> a
> > number.
*Sonnier, Michael
Re:
Options
- Highlight
- Email to a Friend
*Andrew
I do agree with John, that when you do spaghetti line work it would be nice
to see the line work not break around the outer most line work boundary, but
at an other per determined line. I also think it would be nice to be able to
have a pick points rather than the find the distance from the block
insertion points, "F2" ,copy, paste to notepad then input it into the fields
manually. I have had to do this as I created additional schematic riser
diagram symbology and then had to readjusted the insertion scaled size (x12)
to more closely match the 1/4" scale devices we commonly use on a detail
sheet since there is only one (1) drawing setup scale allowed per drawing
(it would be nice if it could be setup per viewport or something). (please
note that if you do change the scale size readjust the drawing setup units
for a 1/256" precision otherwise the inaccuracy gets multiplied as well.)
Michael Sonnier
"John Snocker" wrote in message
news:65DD56750531C5D8A2360D1EFC4A5F4E@in.WebX.maYI adrTaRb...
the
We
engineers
the
> -John Snocker
with
> connector
> any
> > > Hi Andrew -
is
> > device
> geometry
> > scale
> > "visually"
other
> > > problems as well.
> > > jason
> If
> > > the
> geometry"
> all
> mid
> > > standards.
> where
> > > the
> us)
one
> geometry"
> the
> > > circle,
message
> > > > > Hi Andrew -
> connectors
> > it
on
> > the
> > > > > device?
> > > > > jason
> > > > > > Take 2:
> > would
> > > > > link
> assigned
> > a
> > > number.
Michael Sonnier
"John Snocker"
the
We
engineers
the
> -John Snocker
> "Andrew"
with
> connector
> any
> > > Hi Andrew -
is
> > device
> geometry
> > scale
> > "visually"
other
> > > problems as well.
> > > jason
> > > "Andrew"
> If
> > > the
> geometry"
> all
> mid
> > > standards.
> where
> > > the
> us)
one
> geometry"
> the
> > > circle,
message
> > > > > Hi Andrew -
> connectors
> > it
on
> > the
> > > > > device?
> > > > > jason
> > > > > "Andrew"
> > > > > > Take 2:
> > would
> > > > > link
> assigned
> > a
> > > number.
