AutoCAD MEP Wishes
Active Member
Message 1 of 1 (201 Views)
Circuit Manager
201 Views, 0 Replies
05-29-2009 05:02 AM
When will Circuit manager become a worthwile utility.
I need to be able to work with lighting, small power, power and distribution constructs so that I only have to position a distribution board once in a project. In a plant room a panel may need to appear on a mechanical layout as well.
I need to be able to connect devices on the lighting and power constructs to the distribution boards on the distribution board constructs.
I need to be able to connect the distribution boards/panels together as necessary.
I need to be able to export the data to a thirdparty software such as Amtech and import the results back again for my Schematic.
http://www.amtech-power.co.uk/
As it is I doubt if an electrical engineer even looked at it.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
