AutoCAD MEP Wishes (Read Only)
Message 1 of 1
magnolouis
696 Views, 0 Replies
ACAD MEP BOOST
1. How about if Autodesk can provide MS excel sheet the has a linked text in the dwg file, So that Scheduling for Panels/Air Terminals/Equipment etc. will be more easy. Forget about the objetcs to resize with the text thats to lazy enough lets not forget that objetcs are alredy smart since you can just draw everything in 3D with 2D @ the same time in AMEP. The importatn thing is to same sometime and effort.
2. What if AMEP creates a standard filing system for dwgs. sort of an Revit style. Everything will be possible if text can be linked to excel sheets again and will be more wonderfull if the layout-drawing file also will be linked vice versa.
Hope just one of this might come true, what's a fairytale would like without a wish come true. hihihi...
0 REPLIES 0
