Thank you for fixing the duct hatch lineweight issues with SP2.
The duct hatch scale could have an option for "Drawing Scale". For example,
our return hatch is a line pattern, 45d angle, with a scale of 96 for 1/8"
drawings. For 1/4" drawings we change the scale to 48. If we could tie
this to the drawing scale, it would save setup time. You could also go a
step farther and allow equations. For exhaust duct we use the dot hatch
pattern with a scale of 60 for 1/8" and 30 for 1/4". If we could put in
(drawing scale*.625) it would also be a time saver.
"Andrew" wrote in message news:40c73d60$1_2@newsprd01...
> Duct hatch is NOT compatible with stb style plotting. Below is the answer
> I
> got from subscription online help:
> "I heard back from our product development organization and they confirmed
> that the problem you have encountered is a limitation within the current
> release of Building Systems. Accordingly, this issue has been logged with
> our product development team and they will be investigating a resolution
> to
> this problem.
> Unfortunately this does not leave us without a solution to this problem.
> I
> did some research and came up with two potential work-arounds:
> 1. When you are ready to plot, use the Export to AutoCAD routine to reduce
> all Building Systems (and Arch Desktop) objects to basic AutoCAD entities
> and then adjust the lineweights as necessary.
> 2. Use the new Horizontal 2D Elevation routine to generate a 2D elevation
> of
> your plan view, which you can then modify to produce the desired plotted
> results.
> I understand that both of these options would be difficult to implement
> but
> they should work in the absence of a fix for this problem."
> Neither of these solutions are viable.
> Please address this in future releases.
> "Andrew" wrote in message news:409808f9_1@newsprd01...
>> Thank you for including duct hatch capabilities in this release. It was
>> a
>> good effort but it falls quite short of expectation. Attached are two
>> images. The first is from ABS 2005 showing some of the display problems.
>> The second is what I would like the software to be able to do.
>> A quick rundown of the problems:
>> 1. Duct hatch should trim around labels.
>> 2. Duct hatch of lower ducts should break so hatches of separate ducts
>> won't overlap.
>> 3. The hatch on risers/drops and fittings is offset from the rest of the
>> duct hatch.
>> 4. Notice the green duct labeled "duct at 20'-0"". The drop towards the
>> left side of the duct shows duct hatch for the duct as well as the riser,
>> resulting in a pattern twice as dense as the rest of the duct.
>> 5. The display order of the hatch is set to be above the duct it is part
>> of. With solid hatch, it covers the edges of the duct and makes it hard
> to
>> read. It also won't print correctly unless "lines merge" is checked in
>> printing preferences.
>> 6. There also seems to be a problem with duct hatching and .STB's
> (although
>> I am still testing this, I think it should still be mentioned). I have
> set
>> the display property/style overrides for duct hatch two different ways.
>> A. I made a "duct hatch" layer, assigned color, lineweight, plot style,
>> etc. and assigned it to the hatch layer (under layer/color/linetype). I
>> then assigned the other options to be bylayer.
>> B. I left the layer set to the default "0". I then changed the color,
>> linetype, lineweight, ltscale, and plot style overrides.
>> Method A resulted in the hatch taking on the ductwork properties both
>> onscreen and when plotted. Method B resulted in the duct looking correct
> on
>> screen, but when plotted, it ignored the override settings and the hatch
>> took on the properties of the ductwork. So in both instances, the plot
>> showed ductwork and hatch with the same lineweight. And the solid hatch
>> I
>> set to be 30% screened, came out as black. Is there another way to
>> accomplish this?
