I wonder what Autodesk sells in UK.
In my copy I do have both SECT and SECTHIDE keys and both define same layer
A-sect.
When highlighting and right-clicking the x-section, I do not have any
"linework" item in the pop menu.
Still I would appreciate if anybody from Autodesk would bother to reply to
my original post about x-referencing sheets with x-sections into final
drawing and about color change.
sp
"djarvis" wrote in message
news:f1a440e.7@WebX.maYIadrTaRb...
> In my layer key, I have 2 keys, one for SECT, the other for SECTHIDE,
specifying that these objects go onto the A-Section-G layer, I assume that
if you wish to have multiple layers inside your section reflecting the plan
you need to add layer keys for these items and update the section style?!?
Anyway, after you have made your section you can modify the entities inside
the section without exploding it using the following method, not as good as
we would all want but I guess in ABS2005 we may get something better...
> Use this procedure to edit individual lines in a 2D section by assigning
them to display components in the section.
> You can assign selected linework to fixed display components that
determine the display of every section that you generate, or you can assign
linework to display components that you have defined. For information about
adding custom display components, see Adding a Display Component to a 2D
Section Style . After you assign linework to display components, you can
change the display properties (visibility, color, layer, lineweight,
linetype, and linetype scale) to change the display of lines.
> Select the section to be changed, right-click, and click Linework Edit.
> Select the lines that you want to assign to a display component,
right-click, and click Modify Component.
> A list of available display components is displayed.
> Select the component on which to put the lines.
> For example, to make the lines invisible, select Erased Vectors for
Linework Component.
> You can also click (Match existing linework) and select linework in the
section whose display component you want to match.
> Click OK.
> To finish the linework editing process, select any line in the section,
right-click, and click Edit in Place Save Changes to save the changes you
made, or click Edit in Place Discard Changes to undo your linework changes.
