Hi folks,
I've started recieving drawings from a consultant made using Autodesk
Building Systems 3. We're trying to open them in ADT3.3 SP2 and it ain't
happening.
So, I attempted to install the OE for ABS3 and I get the following error
message...
"Autodesk Building Systems 3 Object Enabler is not compatible with the
version of AEC ObjectDBX currently installed on this machine.
Please remove any older Object Enablers or update installed products."
The problem is that I did just that and removed an OE that was installed and
also made sure sp2 was installed. AutoCAD 14 had also been installed on that
computer so I removed that to be safe. Still no luck. It won't even allow me
to re-install the OE that had been on there before.
Thanks for your input,
Jim Bednarz
IT Administrator/ CAD manager
