AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
sizes limited by rules
2 REPLIES 2
tompilzys
540 Views, 2 Replies
I want to create the parametric part but one of the dimensions must be limited by the other dimension. For example if user puts "Length1=5", it means that "Length2" must be 5 or lower. Is it even possible?
2 REPLIES 2
Keith.Brown
in reply to: tompilzys
Yes you can.  You need to create a part size validation test parameter and set it equal to a calculation and then input the formula Length2 =< Length1.  That should restrict the part to the correct size.
tompilzys
in reply to: Keith.Brown
You helped me again, thanks 🙂
”Boost
