scaling a multiple blocks in place is easy... select the block, select similar, adjust the scale value.
But, with devices, no scale value appears in the properties. Is there a trick I don't know about?
Solved by VitalyF. Go to Solution.
Has this ever been figured out? I can scale devices up or down using the scale command, but the actual scale property is nowhere to be found on the properties palette (in AutoCAD MEP, 2023)..
