I have Autocad 2015 and it look as though those 3 options are unavailable when I click on the 'Contextual tab series' under 'ribbon options'
May you please advise. I am having the same frustration. Please find attached.
thank you,
Katherine
in 2015 they removed the ability to turn off the contextual tab state. In the past the ribboncontextselect variable would turn it on/off but this has also been removed from the software. Currently the only way that I know of is to go into the CUI and under contextual tabs select the tab and then under properties change the Contextual Display Type from Full with focus to Full without focus. This will still bring up the tab but will not automatically switch to it. You will have to do this for each tab you are having issues with.
I am not sure why autodesk removed this ability. It might have something to do with them also removing the classical workspace in Vanilla AutoCAD. In otherwords going full force with the ribbon and forcing users to use it the way that they want.
Here's 2 separate ideas:
Option 1 - If you're really unhappy with the Contextual Ribbons, then completely remove all of the contextual tab states from your CUI. To do this, open your CUI Editor by typing in 'CUI' in the command prompt. In the left pane, you'll see "Ribbon," Expand this, and you should see "Contextual Tab States." (See Image #1) Expand this. Here, is a pre-defined list of what I believe is every type of object "selected." Some objects have nothin, others have a Ribbon Tab associated with them. Simply right click on that particular tab, and select "Remove." See Image #2.
Option 2 - If you're like me, and see a potential increase in effeciency when an object is selected, then consider taking the time to customizing your Contextual Tab States. For example, if you select a multi-leader, what might you need to do with it? Check it's layer? Add a leader, remove a leader? Change it's style? Well, by default, the layer and Leader panels are on different ribbon tabs. So, I created a new Ribbon Tab called "Multileader Selected." I added the Layers, Leaders, and Display Order to that ribbon, and then added that to the Multileader Selected Contextual Ribbon State. Formore information on how to do this, use this link:
Don't think of how the software is slowing you down. Instead, look at the feature, and how it can work to your advantage.
