There are a couple things that should be done which will help you out. I
assume that you are running building systems 3 and Architectural desktop
3.3.
1. Make sure that you have service pack 2 for ADT3.3. You should be able to
get that at www.autodesk.com/ArchDesktop then click on Data & Downloads,
then Updates & Service Packs. Now click the ADT3.3 service pack 2 that fits
your situation.
2. Get the object enabler for Autodesk Building Systems. Go to
www.autodesk.com/Bldgsys then click on Data & Downloads then Utilities and
Drivers and get the Autodesk Building systems 3 object enabler.
hth
jason martin
"afinke"
wrote in message
news:f153db6.-1@WebX.maYIadrTaRb...
> Question the firm I work for we have mechanical and desktop but when we
open a mechincal drawing in desktop the desktop does not bring up the aec
blocks. Is there a patch file that we can download to fix this. This can get
bad cause if a person using desktop open our dwg. and recoveris it and then
saves it lose all the work done so I am hoping there is something we do.
