AutoCAD MEP General
New Member
yami_akai
Message 1 of 2 (1,230 Views)
locked layer fading
1230 Views, 1 Replies
04-30-2012 10:08 AM
I have xref's as my backgrounds and they are on a locked layer. The layer is faded because of the layer being locked. How do I get the layer to print faded like that? It used to do it in 2011, but when I upgraded to 2012 it stopped doing it.
Valued Contributor
jcampbell
Message 2 of 2 (1,220 Views)
Re: locked layer fading
05-01-2012 06:13 AM in reply to: yami_akai
The layerfade and xreffade controls are just a visual on-screen fade and do not affect plotting.  The only way I know to affect plotting like this besides applying a pen table or changing the layer color of the xref layer is to use the layer transparency options.  Starting with 2011 we were able to add a layer transparancey in the layer manager for selected xref's.  I use a filter to select the xref layers and then apply like a 70% transparency level. When plotting, make sure you check the "Plot transparency option"  This should get the affect you are looking for.
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
