i have looked for this issue on here and other places and no luck. when i am in top view the model is fine but when i switch to iso view all of my duct except for a 5 pieces are gone. i can understand if it was consistant but like i said only a short piece of duct shows in all the different layers. i can select the duct in plan view and switch to iso and the grips are there just no duct. i have to tag my duct, but i have duct on top of duct so i need the iso view.
my file is to big to attach
please help
ok i figured out what i did. now i just need to fix it. i cut a section through a wall which worked great, not for some reason when i switch the iso view it only shows my section cut. please help. in plan view it shows my whole model but in iso it only shows what is in my section.
ok i got it fixed i accidently made it a live section. right clicked on the section and disabled the live section and now i can see everything again in my iso view.
just in case anyone else has this happen to them
Thanks for posting the solution. I did the same exact thing with Conduit. Worked like a charm.
