AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
invalid enum map string:Aerator
3 REPLIES 3
blackeagle1245
665 Views, 3 Replies
I get this error message while tring to add mvpart. After clicking ok six times I can add mvparts. How can I get rid of this error message?
Thx in advance
3 REPLIES 3
mlmoore
in reply to: blackeagle1245
This error happens when the part has too many or two few connectors.  Each part has a certain number of connectors assigned and if the part does not match it gives the error.  Elbow has 2 a cap has 1 etc.  An Aerator probably has one connector so if you check the part in catalog editor it should be possible to see how many connectors it has.
Micaletti
in reply to: mlmoore
I don't think so. An Enum is a list of strings, each with an integer key. Each part type is hard coded into AMEP. In this case, the 2012 API shows "Aerator" to be 1076.
Are you using a newer part with an older version of AMEP? That is one possible cause for this error . The "Aerator" might not exist in that version of AMEP.
Steven Micaletti
Virtual Mechanical
Software & Content For AMEP
blackeagle1245
in reply to: Micaletti
Still I couldnt find any answer what should I do? Should I delete aerator?
”Boost
