In MEP 2012 i had no problem to connect flexible to grills. Now i open the same drawing in MEP2013, i delete flexible, i i try to add it again and there come tooltip exclamation mark between connections....
They are both the same routing preferences and diameter. NO idea what could have changed.
Anyone can help here?
Regards
i think, it's just a question of class type configuration.
Try the same in a new drawing based on the .dwt used by Autocad MEP by default.
Opening up previous drawings in the current version frequently causes issues with connections. If you regenerate the objects using OBJRELUPDATE do the connects fix themselves?
I tried a few solutions, nothing helped. I deleted that part of ducts and redrawed it. And then it was ok. So everywhere where i needed to make some changes i redrawed the parts. I guess it is problem of different versions. In other drawings i dont have this problem, so nevermind. It must something about that specific drawing.
