I had my new diffuser tag all worked out. Exploded an air terminal device tag, moved things around, change text styles, changed layers from 0 to G-anno-std-text-tag . I did the definetag command and when I select the insert point, the tag goes to about 1/10 of it's size.
Is there a variable that I accidently turned on that is rescaling the tag as it is beign created?
Solved by TheH. Go to Solution.
Solved by Keith.Brown. Go to Solution.
Before you redefine the tag, you need to make sure that your annotation scale is set to 1:1 and that your text is non annotative and set to 1" tall. This will make it appear correctly once you create a tag.
