AutoCAD MEP General
Member
Message 1 of 3 (594 Views)
custom tag
594 Views, 2 Replies
11-08-2012 02:40 PM
I had my new diffuser tag all worked out. Exploded an air terminal device tag, moved things around, change text styles, changed layers from 0 to G-anno-std-text-tag .  I did the definetag command and when I select the insert point, the tag goes to about 1/10 of it's size.
Is there a variable that I accidently turned on that is rescaling the tag as it is beign created?
Keith.Brown
Message 2 of 3 (593 Views)
Re: custom tag
11-08-2012 02:43 PM in reply to: TheH
Before you redefine the tag, you need to make sure that your annotation scale is set to 1:1 and that your text is non annotative and set to 1" tall.  This will make it appear correctly once you create a tag.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
Member
Message 3 of 3 (551 Views)
Re: custom tag
11-12-2012 01:46 PM in reply to: Keith.Brown
Thanks. That was the problem.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
