Anyone else have this issue with using MEP 2012? I get this odd pop up that appears twice with an exclaimation point when closing out of the program. My boss even has the same issue. This does not appear to effect the files or program in anyway as far as we can tell. However when I chose exit autocad mep through the application menu this does not appear.
any thoughts?
The blank alert window is caused by installing AutoCAD 2013. It is a harmless message and doesn't mean that anything has gone wrong. We're looking into releasing a fix for this, but if you uninstall and reinstall AutoCAD MEP 2012, that should fix it.
