AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
change airflow units in m3/h
11 REPLIES 11
Message 1 of 12
menline
2199 Views, 11 Replies
In our country (The Netherlands) is it normal to use m3/h instead of l/s for the airflow.
Is it posable to change that in Autocad MEP
Regards
Menno de Vries
MENLINE Technical drawing office
11 REPLIES 11
Message 2 of 12
blackeagle1245
in reply to: menline
has anybody found an answer for it? I need to do the same
Message 3 of 12
Mr.Mohr1899
Since 2011, you can change airflow units with command UNITS.
Christophe Legrand
Message 4 of 12
how can
Message 5 of 12
Mr.Mohr1899
You can change it if you have AMEP 2011 or earlier.
You have a TAB called HVAC, and you can change units.
Message 6 of 12
we are looking at the same menu. Yours in french I think. But we have four common tabs but you have fifth tab which I dont. What have you done extra to get this tab?.
Message 7 of 12
I installed mep update 2 for 2011 still there is no tab as Hvac. ARe you using mep 2012?
Message 8 of 12
i use Autocap MEP (D-A-CH) 2011.
D-A-CH means Germany-austria-Switzerland.
Message 9 of 12
so how can I get that tab? anybody has an idea?
Message 10 of 12
menline & black eagle, what language are you using?
I believe that the UNITS > HVAC option showed up in the German language version before the US version... I don't have it on my AutoCAD MEP 2011 US version, and I wouldn't expect you to have it either ;).
I do have it in 2012.
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
Message 11 of 12
menline
in reply to: Martin__Schmid
I am using the english version
Message 12 of 12
blackeagle1245
I'm also using english version, I dont have it neither.
”Boost
