AutoCAD MEP General
New Member
brian.cervi
Message 1 of 4 (431 Views)
architectural catalogs in MEP 2013
431 Views, 3 Replies
08-07-2012 06:19 PM
I have just upgraded to MEP 2013 from 2012 and have just gone to use the default catalogs in content browser only to find the aec ones missing does anyone know how to install them.
Regards
Brian
Keith.Brown
Message 2 of 4 (406 Views)
Re: architectural catalogs in MEP 2013
08-09-2012 09:57 AM in reply to: brian.cervi
Go into your windows control panel and choose uninstall a program.  Then select Autocad MEP 2013 and choose change.  This will bring up the installer and allow you to install compenents that were not installed the first time around. Choose Add/Remove content and make sure to check the architectural compenents.  You might need your original installation media at this step.  I am not sure though.
Hope this helps and good luck!
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Product Support
Joshua.Benoist
Message 3 of 4 (402 Views)
08-09-2012 02:01 PM in reply to: Keith.Brown
You will need the original installation media to install the Architectural content packs, yes.
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Support Specialist
Product Support
Product Support
Joshua.Benoist
Message 4 of 4 (384 Views)
08-10-2012 01:10 PM in reply to: Joshua.Benoist
Following up.  Did the above help?
Joshua
Joshua Benoist, PE
Product Support
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
