AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
add schematic pipe fittings are not showing up in the dialog box?
2 REPLIES 2
529 Views, 2 Replies
My schematic pipe fittings arent showing up in the dialog box. I had ran
into this problem in BS3 once and a while. Is their a setting that needs to
be set for them to show the diagram?
Scott
RGD
2 REPLIES 2
Hi Scott,
Are you seeing blank Schematic Pipe Fitting preview icons? It can be a known
display issue.
Kevin Mak
[Autodesk]
"scott" wrote in message
news:62A99586E9C7053762F7026406EAC860@in.WebX.maYIadrTaRb...
to
> Scott
> RGD
Scott,
Please try to open Display Manager, select Schematic Pipe Fitting under
Representation by Object and check the "Model - 1 Line" checkbox. See if
that will fix the problem.
Kevin Mak
[Autodesk]
to
> Scott
> RGD
”Boost
