What is your new way of publishing the tool palettes? I am trying to build the catalog, but running into the same problem. Locked... However when we upgrade to the new acad version, it seems we can not keep the tool palettes in the groups! So frustrating. Is this just a importing function or do we need to start from scratch, building into the catalog on a local hard drive, then publish to the server?
Thanks for your help.
In case somebody can use this information, here it is.
I found a post on AUGI that suggested the following:
"if you have multiple tool palette paths in your options > Files tab > Tool Palettes, then you can only edit the tool palettes in the folder on the top of the list".
I looked at mine and I moved up the file location I was trying to work in. IT WORKED!
Learned something new today. Just think what I will know tomorrow!
Michael
Thanks @mviscetto. This solution worked like a charm on my locked palettes in AutoCAD 2019.
