AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Unhandled Exception after SP1 installed AutoCAD MEP 2013
3 REPLIES 3
PEDROCQ
611 Views, 3 Replies
I have had AC13MEP crashing consistently (Bear in mind this software has worked fine for the previous 6 months since I installed it) a few times a day and finally decided to log an error online through the automatic popup. I got an email from AutoDesk CER recommending I install the maintenance update. I clicked on the link like a 'drone' and downloaded.
AutoCAD MEP 2013 x64 Service Pack 1 (52.159 MB)
...and installed.
Now, lo and behold, I can't use AutoCAD at all; why am I not surprised!
So I restarted a couple of times, to no avail. Error message attached, ye olde Unhandled Exception Error...
So now I am on the search for a solution.
I found a info on how to uninstall the "Service Pack" (cough), which I did, thinking that all would return to normal, NOT.
My search continues..... in the meantime I have $5.5 thousand dollars worth of software I can't use and clients banging on my door wanting documents, and nowhere to turn to, as usual.
Does anybody out there any wise words of advice?
Thanks. I will post here if I find a solution.
3 REPLIES 3
david.lau
in reply to: PEDROCQ
Can you try to uninstall the update?
http://upandready.typepad.com/.a/6a0147e3c68bef970b017d3c7c2a20970c-pi
David Lau
PEDROCQ
in reply to: david.lau
Thanks David Lau, did you not read my post?
david.lau
My apologies....I will try to put down some of my thoughts based on post:
1.  Unhandled errors are notoriously hard to resolve.  Put this into google:
unhandled site:http://upandready.typepad.com/
If we have solved this error, we would have documented it our blog.
2.  If it was working, I would suggest maybe using a Windows Restore point and go back before you ran the update.
3.  One reason for intermittent crashing is hardware and graphics cerifications.  Please check out the following:
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
David Lau
”Boost
