I'm trying to set up my style manager but it only shows parts up to 2". I've going through the catolog editor which shows all sizes but i can seem to get them into the program. Here is a snap show of what i'm talking about.
I believe your problem is one of the fittings you are using for the default such as elbow only goes up to the 2". If a default part is lower than the top size of pipe, it knocks down the size to the top size of the fitting. You can change the smaller fitting to none which requires selection while drawing or make sure the catalog has the larger sizes available for all the fittings and pipe you select..
