AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Unable to execute the tool...
8 REPLIES 8
Message 1 of 9
324 Views, 8 Replies
Hi All!
I'm in the process of setting up ABS4 for network
use and I'm running into some issues with the tool palettes being on the
network.
I've copied the tool palettes folder to our server
and made the corresponding change in the Tool Palettes File Locations section on
the Files tab and have had no luck.
The palettes show up with the images, but when I
click on one of them, I get the following message...
Unable to execute the tool. Possible causes
are:
 - The tool is not registered
properly. Please check your installation.
 - The tool is from another application and
is incompatible with the current application.
I copied the files from the ABS4 installation
location so it must not be registered properly?!?  How do I know if its
registered properly??
Any help will be greatly appreciated!
Thanks in advance!
Matt W
There are 3 kinds
of people:
  Those who can count, and those who
can't.
8 REPLIES 8
Message 2 of 9
Matt,
Check the properties for the tool button and see if
the path structures are correct.  You may have a broken path
statement.  Repair and save.
John Herridge, AIA
Hi All!
network use and I'm running into some issues with the tool palettes being on
the network.
server and made the corresponding change in the Tool Palettes File Locations
section on the Files tab and have had no luck.
are:
appreciated!
Thanks in advance!
Matt W
There are 3 kinds
of people:
can't.
Message 3 of 9
When I check the properties, I get the following
message...
"The tool is not registered properly. You can
only edit the basic properties."
And it still doesn't work.
Matt,
if the path structures are correct.  You may have a broken path
John Herridge, AIA
Hi All!
the network.
I click on one of them, I get the following message...
are:
and is incompatible with the current application.
appreciated!
Thanks in advance!
Matt W
There are 3
kinds of people:
can't.
Message 4 of 9
There are required files that are installed to the following location which
you cannot move (did they move perhaps?):
C:\Documents and Settings\\Application Data\Autodesk\Autodesk
Building Systems 2004\R16.0\enu\Support\RegisteredTools\
chris yanchar | product designer
building solutions division
autodesk, inc.
Message 5 of 9
Chris,
 Those files haven't moved.
 Any other ideas as to what's going
on??
 One thing that I can think of that may
affect this is the fact that our IT Department has so thoughtfully decided to
"lock us out" of our C:\ drive.
 In other words, if you go to My Computer,
the C:\ drive essentially does not exist.
Matt W
There are 3 kinds of people:
  Those
who can count, and those who can't.
There
you
C:\Documents and
Settings\<username>\Application Data\Autodesk\Autodesk
Building
chris yanchar |
product designer
autodesk,
inc.
Message 6 of 9
Can you get your IT department to give one of the computers this is
reproducible on access to their C drives and see if that clears things up?
autodesk, inc.
Message 7 of 9
I'll see what I can do, but I don't specialize in
miracles.
Wish me luck!
Matt W
people:
  Those who can count, and those who can't.
Can
is
up?
building
solutions division
autodesk, inc.
Message 8 of 9
looking at this one sentence only...
makes me shudder - look in the
autodesk.aec.arch-desktop.content newsgroup for a post 9/21 - this is a general
brain noise doc on catalogs...
then I get to the part where the IT has locked out
the C-drive - EeeeeK!!!!
Message 9 of 9
mr_nick
I have just run into the same problem. I have been happily using the section tool for some time now. I have just opened a drawing, attempted to create a section and I get the 'Unable to execute tool' message.
I have looked in the 'Registered Tools' folder and found it to be completely empty. What should be in there and where would the contents have disappeared to between drawing sessions?????
”Boost
