style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Matt" <mattw@bvhis.com> wrote
in message
href="news:2100EE36D8762353A3CACA24789087C4@in.WebX.maYIadrTaRb">news:2100EE36D8762353A3CACA24789......
Hi All!
I'm in the process of setting up ABS4 for
network use and I'm running into some issues with the tool palettes being on
the network.
I've copied the tool palettes folder to our
server and made the corresponding change in the Tool Palettes File Locations
section on the Files tab and have had no luck.
The palettes show up with the images, but when I
click on one of them, I get the following message...
Unable to execute the tool. Possible causes
are:
- The tool is not registered
properly. Please check your installation.
- The tool is from another application and
is incompatible with the current application.
I copied the files from the ABS4 installation
location so it must not be registered properly?!? How do I know if its
registered properly??
Any help will be greatly
appreciated!
Thanks in advance!
Matt W
There are 3 kinds
of people:
Those who can count, and those who
can't.
"John Herridge, AIA" <
href="mailto:john.herridge@aeccadcon.com">john.herridge@aeccadcon.com>
wrote in message
href="news:419B86E78BA13605B1686DBD5AAAC6F9@in.WebX.maYIadrTaRb">news:419B86E78BA13605B1686DBD5AA......
Matt,
Check the properties for the tool button and see
if the path structures are correct. You may have a broken path
statement. Repair and save.
John Herridge, AIA
wrote in message
href="news:2100EE36D8762353A3CACA24789087C4@in.WebX.maYIadrTaRb">news:2100EE36D8762353A3CACA247......
Hi All!
the network.
I click on one of them, I get the following message...
are:
and is incompatible with the current application.
appreciated!
Thanks in advance!
Matt W
There are 3
kinds of people:
can't.
"chris yanchar - autodesk" <There
href="mailto:chris.yanchar@_nospam_autodesk.com">chris.yanchar@_nospam_autodesk.com>
wrote in message
href="news:8DDC1EF7115DAB2FF26A04013A07E1FD@in.WebX.maYIadrTaRb">news:8DDC1EF7115DAB2FF26A04013A0......
are required files that are installed to the following location which
you
cannot move (did they move perhaps?):
C:\Documents and
Settings\<username>\Application Data\Autodesk\Autodesk
Building
Systems 2004\R16.0\enu\Support\RegisteredTools\
chris yanchar |
product designer
building solutions division
autodesk,
inc.
"chris yanchar - autodesk" <Can
wrote in message
href="news:0E154454CDE87772466088935436D318@in.WebX.maYIadrTaRb">news:0E154454CDE8777246608893543......
you get your IT department to give one of the computers this
is
reproducible on access to their C drives and see if that clears things
up?
chris yanchar | product designer
building
solutions division
autodesk, inc.
