Hi Slawomir -
There are some tags in design center, but they are located in the Metric
DACH content, and they are configured to work with display representations
that are not included in the building systems templates.
I've re-posted an old tag example that I did sometime last summer to
customer files. It's called ABS Tagging Example. This particular paper goes
over creating a tag for a schematic symbol, but I think that it covers all
of the items you'll need to create a new area tag.
If you want to be prompted to fill out the MvPart tag information as tags
are added you can go to Options -> AEC Content and put a check mark in the
Display Edit Schedule Data Dialog During Tag Insertion.
If you want to re-size the oval, you'll follow the same general procedure as
for creating the tag, but all you'll need to do is modify the source block.
If I don't provide enough info in the document you can also check out the
"Creating Custom Automatic Schedule Tags" brain dump by Matt Dillon at
http://www.stardsign.com/BrainDumps/Creating_Custom_Automatic_Schedule_Tags.
htm (watch for wrapping).
hth
jason
"Slawomir Popiel" wrote in message
news:D7076EEF0300DAC5FC125EEF8F238BC6@in.WebX.maYIadrTaRb...
> Hi Jason.
> I'm using area function to help with ventilation calculations. After
seting
> areas, I create a schedule containing area number, name, number of square
> feet and number of occupants. Then I transfer it to Excel. Identification
of
> the areas is an issue. I don't know how to make the area number to
display,
> nor I found in the design center any area tags. Could you advise on that,
> please?
> Another matter are equipment tags. Normally, I insert mv-part then I'm
> defining property set, the I'm using equipment tag to idenify it. I
couldn't
> do, however a simple thing like automatic displaying equipment mark in the
> equipment tag. After inserting the tag I have to edit it's properties and
> manually change "000" to desired mark. Am I getting it wrong or right?
> Last thing, the equipment tag format "000" makes possible to enter
> conveniently any number from 001 to 999, however, (I'm sure I'm not
speaking
> only for myself) we would like to have possibility to enter a mark like
> RTU-12, which has better meaning than for example 137, but it will extend
> beyond oval line.
> Any idea how to circumvent the matter? Subject of creating tags and
> automating entries is somehow extraordinarily brief in the manuals and
> guides and does not exhaust the matter.
> Thanks,
> sp
