AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
TURNING INSULATION OFF
4 REPLIES 4
mjmpe
1131 Views, 4 Replies
Is there a way of turning the insulation off an entire system without going over every piece of pipe?
4 REPLIES 4
Keith.Brown
in reply to: mjmpe
Yes there is.  Just select one piece of duct from the system and then type SELECTMEPBYSYSTEM.  It will select all duct of the same system.
ashton995
in reply to: Keith.Brown
Are you talking about using the "SELECTMEPBYSYSTEM" command wile you're in Model Space?  This does not seem to be working for me.
Keith.Brown
in reply to: ashton995
What is not working?  It is a standard autocad mep command.
I can select a single piece of duct and run the command and it will select all other objects that belong to that system.  You can also use the command SELECTMEPBYDOMAIN or just use SELECTBYMEP and it will give you all the choices that you can use to select by.
ashton995
I apologize this is working.  I was using Fabrication CAD and that is why the command was not working.  I thought both Fabrication and MEP where the same.
Thanks!!
”Boost
