Is there a way of turning the insulation off an entire system without going over every piece of pipe?
Solved by Keith.Brown. Go to Solution.
Yes there is. Just select one piece of duct from the system and then type SELECTMEPBYSYSTEM. It will select all duct of the same system.
Are you talking about using the "SELECTMEPBYSYSTEM" command wile you're in Model Space? This does not seem to be working for me.
What is not working? It is a standard autocad mep command.
I can select a single piece of duct and run the command and it will select all other objects that belong to that system. You can also use the command SELECTMEPBYDOMAIN or just use SELECTBYMEP and it will give you all the choices that you can use to select by.
I apologize this is working. I was using Fabrication CAD and that is why the command was not working. I thought both Fabrication and MEP where the same.
Thanks!!
