I'm running MEP 2010, which I wish I had never bought, but my question is I have many sub folders that I keep my blocks in listed under a main folder. For some reason the only way I can get the program to search the sub folders is to go in and list each address in the support file search path. Is there some way to include all folders and sub folders without having to list each one? I have a lot of them.
dsandlin
That's how it is done. Would you benefit from switching to ADCENTER or ToolPalettes for blocks insertions? Then you don't need to path every single folder you have.
You could try using folder shortcuts in the top folder, but too many of those and you can overwhelm the system.
