AutoCAD MEP General
Member
eze_90
Message 1 of 3 (426 Views)
Structural Columns and Beams
426 Views, 2 Replies
09-05-2012 08:12 AM
In the Arquitecture tab, when I insert a colum or a beam I can't modify their dimensions (height and wide for the beam for example). Any help? It just let me place the column or beam but not changing the standard.
Thanks!
dvclark5
Message 2 of 3 (419 Views)
Re: Structural Columns and Beams
09-05-2012 11:21 AM in reply to: eze_90
eze,  When you installed MEP if you included Architecture on the install you will have the sturctural member catalog.  Use the command MEMBERCATALOG and you can choose your beam type from the catalog.
hope it helps, and hope you checked Architecture on the install....
Member
eze_90
Message 3 of 3 (404 Views)
09-06-2012 07:39 PM in reply to: dvclark5
thank you! I didn't find the button! the command worked just find! then I found the button! It is not an easy one, lol
You are not logged in.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
