AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Single line Branch Ducting with 2-line Mains???
11 REPLIES 11
Message 1 of 12
328 Views, 11 Replies
Ductwork drawings: Normally we show 2-line medium pressure ducts, VAV boxes, and then a 2-line low pressure main just passed the VAV box. To connect the diffuser to the low pressure main we normally just show that as 1-line. Is there a way to do this within BS2004? All I can tell is it's 2-line or 1-line, no mixing?
11 REPLIES 11
Message 2 of 12
Hi:
You could do it by redefining the display
properties (only turn on Center Line and Center Line Haloed Line) in Duct System
Definitions for specific duct system.
Hope this helps.
Qi Liang
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Ductwork
mixing?
Message 3 of 12
The duct system is all Supply air?
Message 4 of 12
You need to create a new duct system (e.g. Supply -
Low Pressure) for it.
Qi liang
The
Message 5 of 12
Are you using flex to connect to the
diffuser?  If you are, you can accomplish this through overrides.
Right click on the flex duct and select "edit flex duct style".  Set a
2-line override so everything is turned off except centerline.
face=Arial size=2>
Ductwork
mixing?
Message 6 of 12
Message 7 of 12
Yeh, I'll probably have to create a branch layer that would cover the ductwork from the low pressure main to the diffusers.
Message 8 of 12
Well the separate layer option didn't fly with the rest of the group. We've been trying to stay away from having an abundance of layers. So no giving in on this issue. Another way that I found but is very labor intensive is to select each individual piece and then modify the display properties for each element. Works, but like I said it's very tedious. There needs to be a radio button in the properties window to toggle whether to show the elements as single or double line.
Message 9 of 12
You don't have to create a separate layer to create a separate system. Layer
<> System. You can have two systems that are on the same layer, you can also
have one system that has items on multiple layers.
"jmcfaddn" wrote in message
news:f177f4d.6@WebX.maYIadrTaRb...
Message 10 of 12
Ok, thanks. Let me try that.
Message 11 of 12
I've created the separate system. But now the ductwork will not connect to each other. So I went to Format/style manager/multi-purpose objects/connectors, and then turned off the "Systems" rule, thinking this would solve my problem. No such luck. What do I need to do to get the separate systems, but same layer, to connect to each other?
Message 12 of 12
Put the connector rules back the way they were.
Make the two systems part of the same system group (in the system
definitions on the Design Rules tab).
jason
news:f177f4d.9@WebX.maYIadrTaRb...
”Boost
