How might one go about scheduling specific objects within a space or zone?
Solved by Keith.Brown. Go to Solution.
You just need to add a Location based property defintion to a property set attached to the object that points to a property definition that is in a property set that is attached to a space. I don't believe you can link it to a zone directly but i could be wrong.
Then when you place the object in the space, with all property sets attached the information from the space property definition will appear in the location property definition on the object.
