When adding a schedule table that must scan Xrefs or blocks,
use a layer filter that includes both the name of the layer that the Xref or
block is on, and the name of the layer of the object inside the Xref or block.
You can separate multiple layer wildcards with a comma.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"clarkm" <clarkm@leeac.com>Any
wrote in message
href="news:f16cbc9.-1@WebX.maYIadrTaRb">news:f16cbc9.-1@WebX.maYIadrTaRb...
advice on creating one schedule for equipment located on multiple drawings???
When designing a system for a multi-floor building, we generaly have a
seperate drawing file for each floor, & sometimes even a seperate one for
the schedule sheet. We do this as a safety precausion & it make it easier
to have more than one person working on a project at a
time.
"jkemble" <
href="mailto:jkemble@troarch.com">jkemble@troarch.com> wrote in message
href="news:DC1D973D1337B68D9500E79BD5DD5DC1@in.WebX.maYIadrTaRb">news:DC1D973D1337B68D9500E79BD5D......
In release 3 and I assume it's the same in 2004
you could xref the drawing sheets into your schedule sheet and then run the
schedule tables
here is what is says in the help menu in
r3
blocks, use a layer filter that includes both the name of the layer that the
Xref or block is on, and the name of the layer of the object inside the Xref
or block. You can separate multiple layer wildcards with a comma.
name="" nid="8">
wrote in message
drawings??? When designing a system for a multi-floor building, we generaly
have a seperate drawing file for each floor, & sometimes even a seperate
one for the schedule sheet. We do this as a safety precausion & it make
it easier to have more than one person working on a project at a
time.
"Julian Gonzalez [Autodesk]" <
href="mailto:julian.gonzalez@autodesk.com">julian.gonzalez@autodesk.com>
wrote in message
href="news:1C0D8FD78C419274573D840E8C6DE758@in.WebX.maYIadrTaRb">news:1C0D8FD78C419274573D840E8C6......
The process you describe is correct. However,
there are some new enhancements to the scheduling functionality.
For example, you can now schedule an external dwg
file. In other words, instead of Xrefing the dwg sheets into the
schedule sheet, you can simply xref them together into their own dwg. You can
then place the schedule where ever you want it (seperate sheet?) and tell it
to schedule the contents of the other dwg file without needing to
xref.
Also, you can use the classification filter to
specify which devices need to be scheduled instead of relying on
layers.
Cheers,
Julian
"jkemble" <
message
href="news:DC1D973D1337B68D9500E79BD5DD5DC1@in.WebX.maYIadrTaRb">news:DC1D973D1337B68D9500E79BD......
schedule tables
r3
name="" nid="8">
"clarkm" <Any
href="mailto:clarkm@leeac.com">clarkm@leeac.com> wrote in message
generaly have a seperate drawing file for each floor, & sometimes even
a seperate one for the schedule sheet. We do this as a safety precausion
& it make it easier to have more than one person working on a project
at a time.
"jkemble" <
href="news:036E7AB33770083F8746C5F9C75DC55C@in.WebX.maYIadrTaRb">news:036E7AB33770083F8746C5F9C75......
Thanks Julian
Is there anything written(brain dump) that
explains the whole property set, classification and scheduling process for
2004
wrote in message
href="news:1C0D8FD78C419274573D840E8C6DE758@in.WebX.maYIadrTaRb">news:1C0D8FD78C419274573D840E8......
dwg file. In other words, instead of Xrefing the dwg sheets into the
can then place the schedule where ever you want it (seperate sheet?) and
tell it to schedule the contents of the other dwg file without needing to
xref.
layers.
Cheers,
Julian
"jkemble" <
message
href="news:DC1D973D1337B68D9500E79BD5DD5DC1@in.WebX.maYIadrTaRb">news:DC1D973D1337B68D9500E79......
2004 you could xref the drawing sheets into your schedule sheet and then
run the schedule tables
r3
the Xref or block is on, and the name of the layer of the object inside
the Xref or block. You can separate multiple layer wildcards with a comma.
"clarkm" <Any
even a seperate one for the schedule sheet. We do this as a safety
precausion & it make it easier to have more than one person working
on a project at a
time.
"jkemble" <
Thanks Julian
2004
wrote in message
xref.
layers.
Cheers,
Julian
"jkemble" <
message
r3
"clarkm" <Any
on a project at a
time.
